Full Version: KC868-16 ESPHOME firmware connection to node red
I am making a kc868-16 connection with esphome firmware, to connect directly to node red, but the connection is unsuccessful, I have the latest KC firmware.
What should be the ports to use for the connection?
thank you so much
if you want to use home assistant, you can use ESPHome.
if you want to use Node-red, you can download KCS firmware to ESP32, then use MQTT integrate to Node-red.
Perfect, Tks!!!
how do I do it, with:  npm install node-red-contrib-kincony ?
no, not install this node.
use MQTT for integration. this is yaml sample with A8S board: https://www.kincony.com/forum/showthread.php?tid=3274
