08-16-2021, 02:15 PM
I just received my H32B, upgraded to version 4.35 and configured it as follows (I only use wired Ethernet):
[attachment=280]
Unfortunately, the H32B does not connect to my Mosquitto MQTT broker although the MQTT Explorer running on my computer does, using the same credentials.
I tried to reset the configuration using the Ethernet mode button but it did not help.
Did I miss something in the configuration ?
Night update - it finally connected to the Mosquitto addon, without any additional action from my side.
I could set up all relays and inputs and restarted the KC868 to check whether it would re-establish the MQTT connection.
It actually did but after several minutes.
I then restarted the Mosquitto addon but this time the KC868 did NOT reconnect.
I waited for another 15 minutes and then power cycled the KC868.
But even after 10 minutes, it still did not connect to the MQTT broker.
It looks like the MQTT connection still needs work to become more reliable.
[attachment=280]
