04-12-2024, 06:21 AM
[attachment=5078]
download yaml:
friendly_name: a32-Pro
platformio_options:
board_build.flash_mode: dio
board: esp32-s3-devkitc-1
type: esp-idf
# ota:
# password: "5f17bccba50c65f60200db69f1b1ebbe"
# wifi:
# ssid: KinCony
# password: a12345678
# # Enable fallback hotspot (captive portal) in case wifi connection fails
# ap:
# ssid: "A32-Pro Fallback Hotspot"
# password: "25JYfblp8QJP"
# captive_portal:
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO44
miso_pin: GPIO40
cs_pin: GPIO39
interrupt_pin: GPIO41
reset_pin: GPIO43
- id: bus_a
sda: 11
scl: 10
frequency: 400kHz
xl9535:
- id: xl9535_hub_out1 # for output channel 1-16
address: 0x21
- id: xl9535_hub_out2 # for output channel 17-32
- id: xl9535_hub_in1 # for input channel 1-16
- id: xl9535_hub_in2 # for input channel 17-32
address: 0x25
- id: 'pcf8574_in_3' # for input channel 33-40
address: 0x23
- id: uart_1
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 9
rx_pin: 8
- id: uart_tuya
baud_rate: 115200
debug:
direction: BOTH
after:
timeout: 10ms
tx_pin: 15
rx_pin: 16
- id: uart_sim7600
baud_rate: 115200
debug:
direction: BOTH
after:
timeout: 10ms
sequence:
- lambda: UARTDebug::log_string(direction, bytes);
tx_pin: 18
rx_pin: 17
pin: 45
- platform: uart
uart_id: uart_1
- platform: uart
uart_id: uart_sim7600
data: "AT+CGSN\r\n" # read 4G SIM7600 ID
# - platform: uart
# uart_id: uart_tuya
# name: "UART TUYA2"
# data: [0x55, 0xaa, 0x03, 0x00, 0x00, 0x01, 0x01, 0x04]
name: A32 Pro Switch01
xl9535: xl9535_hub_out1
name: A32 Pro Switch02
name: A32 Pro Switch03
name: A32 Pro Switch04
name: A32 Pro Switch05
name: A32 Pro Switch06
name: A32 Pro Switch07
name: A32 Pro Switch08
name: A32 Pro Switch09
number: 10
name: A32 Pro Switch10
number: 11
name: A32 Pro Switch11
number: 12
name: A32 Pro Switch12
number: 13
name: A32 Pro Switch13
number: 14
name: A32 Pro Switch14
number: 15
name: A32 Pro Switch15
number: 16
name: A32 Pro Switch16
number: 17
name: A32 Pro Switch17
xl9535: xl9535_hub_out2
name: A32 Pro Switch18
name: A32 Pro Switch19
name: A32 Pro Switch20
name: A32 Pro Switch21
name: A32 Pro Switch22
name: A32 Pro Switch23
name: A32 Pro Switch24
name: A32 Pro Switch25
number: 10
name: A32 Pro Switch26
number: 11
name: A32 Pro Switch27
number: 12
name: A32 Pro Switch28
number: 13
name: A32 Pro Switch29
number: 14
name: A32 Pro Switch30
number: 15
name: A32 Pro Switch31
number: 16
name: A32 Pro Switch32
number: 17
name: A32 Pro DI01
xl9535: xl9535_hub_in1
name: A32 Pro DI02
name: A32 Pro DI03
name: A32 Pro DI04
name: A32 Pro DI05
name: A32 Pro DI06
name: A32 Pro DI07
name: A32 Pro DI08
name: A32 Pro DI09
number: 10
name: A32 Pro DI10
number: 11
name: A32 Pro DI11
number: 12
name: A32 Pro DI12
number: 13
name: A32 Pro DI13
number: 14
name: A32 Pro DI14
number: 15
name: A32 Pro DI15
number: 16
name: A32 Pro DI16
number: 17
name: "A32 Pro TMP1"
name: "A32 Pro TMP2"
name: "A32 Pro DL"
name: "A32 Pro DTUYA"
number: 21
name: A32 Pro DI17
xl9535: xl9535_hub_in2
name: A32 Pro DI18
name: A32 Pro DI19
name: A32 Pro DI20
name: A32 Pro DI21
name: A32 Pro DI22
name: A32 Pro DI23
name: A32 Pro DI24
name: A32 Pro DI25
number: 10
name: A32 Pro DI26
number: 11
name: A32 Pro DI27
number: 12
name: A32 Pro DI28
number: 13
name: A32 Pro DI29
number: 14
name: A32 Pro DI30
number: 15
name: A32 Pro DI31
number: 16
name: A32 Pro DI32
number: 17
name: A32 Pro DI33
pcf8574: pcf8574_in_3
name: A32 Pro DI34
name: A32 Pro DI35
name: A32 Pro DI36
name: A32 Pro DI37
name: A32 Pro DI38
name: A32 Pro DI39
name: A32 Pro DI40
gp8403:
voltage: 10V
output:
- platform: gp8403
gp8403_id: my_gp8403
channel: 0
- platform: gp8403
channel: 1
light:
- platform: monochromatic
name: "A32 Pro-DAC-0"
output: gp8403_output_1
name: "A32 Pro-DAC-1"
output: gp8403_output_2
- platform: adc
pin: 7
name: "A32 Pro A1 Voltage"
update_interval: 5s
attenuation: 11db
filters:
- lambda:
if (x >= 3.11) {
return x * 1.60256;
} else if (x <= 0.15) {
return 0;
return x * 1.51;
- platform: adc
pin: 6
name: "A32 Pro A2 Voltage"
update_interval: 5s
attenuation: 11db
filters:
# - multiply: 1.51515
- lambda:
if (x >= 3.11) {
return x * 1.60256;
return 0;
return x * 1.51;
- platform: adc
pin: 5
name: "A32 Pro A3 Current"
update_interval: 5s
unit_of_measurement: mA
attenuation: 11db
filters:
- multiply: 6.66666666
- platform: adc
pin: 4
name: "A32 Pro A4 Current"
update_interval: 5s
attenuation: 11db
filters:
web_server:
port: 80
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
i2c_id: bus_a
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 0, id(roboto), "A32 Pro");
