The
Konnected ESP32 alarm panel is extremely popular, but is hard to obtain. I would love to see a Kincony equivalent!
- 20+ digital inputs for door contacts, motions sensors, etc. (the original does not have enough)
- Dedicated 12V wet contacts for powering active 12V sensors.
- Dedicated wet contact 12V alarm connection.
- Power over Ethernet.
- Dedicated piezo buzzer or connection.
it's almost a POE INPUT module. do you think only work with home assistant is OK? or need use cloud server send alarm notification by internet is important?
(04-14-2024, 12:05 PM)admin Wrote: [ -> ]it's almost a POE INPUT module. do you think only work with home assistant is OK? or need use cloud server send alarm notification by internet is important?
I believe only working with Home Assistant is OK.
The people who buy these boards do not rely on cloud servcies!
not need send alarm notification by internet?
if only need work with home assistant, i think the board similar as KC868-AI input module is function. just need make the PCB smallest.
(04-15-2024, 10:21 PM)admin Wrote: [ -> ]not need send alarm notification by internet?
In Europe notification is very important. Every standard security system have to notice user about alarms in dedicated application, CLIP or sms message
Thanks, this product already in our development plan.
(04-14-2024, 09:49 AM)awfulwoman Wrote: [ -> ]The Konnected ESP32 alarm panel is extremely popular, but is hard to obtain. I would love to see a Kincony equivalent!
It already exists, the KC868-A16 is considerably more powerful than the Konnected in that they're mostly the same hardware but the KC868 has far better and more sophisticated I/O than the Konnected. Also if you use the KCS firmware the ladder-logic programmability means you can set up the alarm functionality directly on the board without needing a pile of YAML and Home Assistant controls.
