04-17-2024, 09:28 AM
04-17-2024, 10:29 AM
A32 board not support other RS485 switch panel by KCS.
if you add RS485 adapter with common switch panel , it can work with A32 using KCS firmware.
here is details of RS485 switch adapter: https://www.kincony.com/rs485-io-module.html
04-17-2024, 01:15 PM
(04-17-2024, 10:29 AM)admin Wrote: [ -> ]A32 board not support other RS485 switch panel by KCS.
Can you please help with how to use the RS485 adapter with a switch panel connected to the A32 board running KCS.
04-17-2024, 10:17 PM
i have said, KCS not support, you can try work with ESPHome to decode the RS485 command.
04-18-2024, 09:01 AM
(04-17-2024, 10:17 PM)admin Wrote: [ -> ]i have said, KCS not support, you can try work with ESPHome to decode the RS485 command.
Is it possible to use your RS485 adapter with your dry contact switch panel to control the relays on the A32 board?
04-18-2024, 10:36 AM
sure, it's ok.
04-18-2024, 11:13 AM
(04-18-2024, 10:36 AM)admin Wrote: [ -> ]sure, it's ok.
Can you please shown me how?
04-18-2024, 11:28 AM
see here online guide: https://www.kincony.com/how-to-use-rs485...apter.html
also we have video tour on our YouTube channel.
