04-28-2024, 05:21 AM
This is an arduino sample code for KC868-ASR , auto control relay ON/OFF by date and time. for example ,the demo is every year 4-26 (April 26th) relay will ON, every year 5-2 (May 2nd) relay will OFF. it support command by serial port (USB cable) to send date/time and read date/time.
[attachment=5148]
source code download ZIP file: [attachment=5144]
before use code need install DS3231 arduino library firstly.
[attachment=5145]
download firmware by arduino IDE:
[attachment=5146]
serial port by USB 115200bps
set date and time command example: D2024-04-28T11:50:22
print current date and time: current time
[attachment=5147]
[attachment=5149]
because it's not easy to battery by air plane, so if you want timer work when power off, you can install the CR1220 on KC868-ASR PCB bottom side.
[attachment=5150]
[attachment=5151]
[attachment=5148]
#include <DS3231.h>
#include <Wire.h>
String serial_cmd_rcv = ""; //serial port receiver
typedef struct
byte year;// Last two digits of the year, lib will add 2000.
byte month;
byte day;
byte hour ;
byte minute ;
byte second ;
}MY_DATE_STR;
#define OPEN_RLY_DATA 26
#define OPEN_RLY_MONTH 4
#define CLOSE_RLY_DATA 2
#define CLOSE_RLY_MONTH 5
#define SDA_PIN 26
#define SCL_PIN 27
#define RLY1_PIN 19
#define RLY2_PIN 5
DS3231 rtc;
bool h12Flag;
bool pmFlag;
static bool bCentury = false;
static bool CompareOpenDate()
return (rtc.getDate()==OPEN_RLY_DATA)&(rtc.getMonth(bCentury)==OPEN_RLY_MONTH);
static bool CompareCloseDate()
return (rtc.getDate()==CLOSE_RLY_DATA)&(rtc.getMonth(bCentury)==CLOSE_RLY_MONTH);
static void PrintfCurTime()
Serial.print("current time is: ");
Serial.print(year);
Serial.print("-");
Serial.print("-");
// then the date
Serial.print(" ");
// and the day of the week
//Serial.print(rtc.getDoW(), DEC);
//Serial.print(" ");
// Finally the hour, minute, and second
Serial.print(":");
Serial.print(":");
static void GetSerialCmd()
{ ////format:D2024-04-28T11:50:22
/*while (Serial.available() > 0)
delay(5);
if(Serial.available() > 0)
delay(100);
while(num_read--)
else return;
serial_cmd_rcv.trim();
if(serial_cmd_rcv == "current time")
PrintfCurTime();
return;
Serial.print("rcv length:");
Serial.print("d index:");Serial.print(indexof_d);
Serial.print(" t index:");Serial.println(indexof_t);
serial_cmd_rcv.substring(0,1) != "D" ||
serial_cmd_rcv.substring(11,12) != "T")
serial_cmd_rcv="";
return;
Serial.println("setting is start!");
my_date_str.year = (byte)serial_cmd_rcv.substring(3,5).toInt();
my_date_str.month = (byte)serial_cmd_rcv.substring(6,8).toInt();
my_date_str.day = (byte)serial_cmd_rcv.substring(9,11).toInt();
my_date_str.hour = (byte)serial_cmd_rcv.substring(12,14).toInt();
my_date_str.minute = (byte)serial_cmd_rcv.substring(15,17).toInt();
rtc.setDate(my_date_str.day);
Serial.println("setting is ending!");
static bool GetEdgeP(bool cur,bool old) {return (cur & !old);}
static bool bOpen,bClose;
// Start the I2C interface
Wire.begin(SDA_PIN,SCL_PIN,40000);
// Setup Serial connection
pinMode(RLY1_PIN,OUTPUT);
pinMode(RLY2_PIN,OUTPUT);
// Set 12/24h mode. True is 12-h, false is 24-hour.
rtc.setClockMode(false);////24h
PrintfCurTime();
while(Serial.read()>=0){}
GetSerialCmd();
bOpen = CompareOpenDate();
bClose = CompareCloseDate();
if(GetEdgeP(bOpen,old_level_high)) digitalWrite(RLY1_PIN,HIGH);
if(GetEdgeP(bClose,old_level_low)) digitalWrite(RLY1_PIN,LOW);
old_level_high = bOpen;
old_level_low = bClose;
//delay (1000);
[attachment=5145]
[attachment=5146]
[attachment=5147]
[attachment=5149]
[attachment=5150]
[attachment=5151]
