Full Version: output turns off automaticly
Hello, I have two Kincony A16 boards. Im using toggle buttons, but after some time output automatically turns off, and this happens with both Kincony boards with every output, wiring is good, what can be the reason? This how the code looks like:
  friendly_name: Kincony2
  sda: 4
  scl: 5
  encryption:
    key: "pbLoAOpRUI49e65b0pCUrVShaclU3bM38vlGfnNQ9YY="
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esphome-Web-Af6E50"
    password: "ajhfwy1kFdbc"
captive_portal:
# Example configuration entry
  - id: 'pcf8574_output1'  # for output channel 1-8
  - id: 'pcf8574_output2'  # for output channel 9-16
    address: 0x25
  - id: 'pcf8574_input1'  # for input channel 1-8
  - id: 'pcf8574_input2'  # for input channel 9-16
    address: 0x21
  friendly_name: Kincony1
  sda: 4
  scl: 5
  encryption:
    key: "tBC8hXDhMHsgklwFmZerS9tVQP0p+6Qus3+OyUTj+Jo="
ota:
wifi:
  ap:
    ssid: "Esphome-Web-B050E4"
    password: "SziFua377JQb"
captive_portal:
    address: 0x25
    address: 0x21
# Outputs
    name: "Living room "
      pcf8574: pcf8574_output2
# Inputs
    name: "Living room switch"
      pcf8574: pcf8574_input1
    on_press:
      then:
        - switch.toggle: livingroom
ESPHome config yaml you can use this one: https://www.kincony.com/forum/showthread.php?tid=1628
take a photo of your whole board wire, board, power supply and load. maybe some hardware problem if you are using the ymal link given you.
