Full Version: Board Boot Error
Hi I have an A16 v1.5 board that will not flash.
[attachment=5253]
[attachment=5252]
[attachment=5254]
From doing some reading this is a fatal error....
do you have connected USB-C cable and power supply ?
note: when you download firmware, need remove 433Mhz RF receiver module.
(05-14-2024, 07:49 AM)admin Wrote: [ -> ]do you have connected USB-C cable and power supply ?
Yes
while programming I had the usb-c cable (known working) & well as known good 12V 5A power connected & RF module was not connected.
do you have installed USB-Serial port driver first. you can install by this link: https://www.kincony.com/download/CH341SER.zip
(05-14-2024, 11:20 AM)admin Wrote: [ -> ]do you have installed USB-Serial port driver first. you can install by this link: https://www.kincony.com/download/CH341SER.zip
Yes drivers are installed (I have 2 x KC868-A8 & 1 x KC868-A6 which work fine).
can you try do "ERASER" firstly.
(05-15-2024, 11:47 AM)admin Wrote: [ -> ]can you try do "ERASER" firstly.
I tried Eraser
Log Output:
test offset :  0 0x0
case ok
Uploading stub...
Running stub...
Stub running...
FLASH_CRYPT_CNT 0
ABS_DONE_0 False
Exception in thread Thread-1:
Traceback (most recent call last):
  File "threading.py", line 932, in _bootstrap_inner
  File "download_process.py", line 664, in run
  File "espDownloader.py", line 517, in flash_erase_test
  File "espDownloader.py", line 1868, in flash_erase_func
  File "espDownloader.py", line 663, in esp_flash_erase_and_clr_protect
  File "esptool.py", line 154, in inner
  File "esptool.py", line 961, in erase_flash
  File "esptool.py", line 495, in check_command
  File "esptool.py", line 468, in command
  File "esptool.py", line 413, in read
  File "esptool.py", line 3453, in slip_reader
esptool.FatalError: Packet content transfer stopped (received 8 bytes)
[attachment=5272]
what power supply you have used?
can you try another USB-C cable.
(05-14-2024, 08:10 AM)corkers Wrote: [ -> ]
Yes
(05-16-2024, 09:48 AM)admin Wrote: [ -> ]what power supply you have used?
Tried 3 different cables all same result. All cables tested & working on other devices.
Tested with 5A 12Vdc power supply & also tried 12V 2A dc power supply.
add whatsapp number: +86-15381188302 we use anydesk remote control your computer to help you.
