Full Version: Rs485
(06-29-2024, 01:34 AM)admin Wrote: [ -> ]download KCS firmware to A6 board, enable RS485 using MODBUS-RTU. just login KCS webpage to set.
Sorry, I'm not using KCS firmware for the A6 board.
I flashed the A6 board with a basic yaml file downloaded from ESP Home support pages.
So I only need to add to the yaml file the correct lines in order to:
  • enable RS485 using MODBUS-RT,
  • setting address, baudrate, parity, stopbit and so on...
Could you show me the details? Thanks in advance
i already sent you video tour link, just do as that .
(06-27-2024, 10:31 PM)admin Wrote: [ -> ]if you are first time to use server-mini,  you need to enable serial port for CM4, here is details :
https://www.kincony.com/forum/showthread.php?tid=1971
I was able to find the config.txt file on my Sd card and set enable_uart=1
Unfortunately trying to disable Linux Uart console I go to the homeassistant terminal and when I try the command
sudo raspi-config
I get the message command not found.
Any hint for this step?
where you installed home assistant software? raspberry pi?
which home assistant firmware you have installed?
(07-07-2024, 11:13 PM)admin Wrote: [ -> ]where you installed home assistant software? raspberry pi?
home assistant installed onto KC868-Server Mini with CM4 and SD card.
the firmware installed was
haos_rpi4-64-7.4.img
At the moment I have
Home Assistant Core 2024.7.0
          Supervisor 2024.06.2
          Operating System 12.4
          Frontend 20240703.0
can you take a video of your problem, when you input "sudo raspi-config" have error. send video to whatsapp number: +86-15381188302
