06-14-2024, 03:03 AM
friendly_name: ag8
platformio_options:
board_build.flash_mode: dio
board: esp32-s3-devkitc-1
type: esp-idf
sdkconfig_options:
SOC_RMT_SUPPORT_RX_PINGPONG: "n"
encryption:
key: "dolIFOGZiGF8GT9wSJVBuoNzVQSHanaieBBbRcj1t48="
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
interrupt_pin: GPIO2
reset_pin: GPIO1
remote_receiver:
pin: 48
rmt_channel: 4
dump: all
remote_transmitter:
- id: ir1
pin: 9
carrier_duty_percent: 50%
- id: ir2
pin: 10
- id: ir3
pin: 11
- id: ir4
pin: 12
# - id: ir5
# pin: 13
# carrier_duty_percent: 50%
# - id: ir6
# pin: 14
# - id: ir7
# pin: 21
# - id: ir8
# pin: 47
- platform: template
turn_on_action:
- remote_transmitter.transmit_panasonic:
transmitter_id: ir1
address: 0x4004
command: 0x8140DFA2
turn_on_action:
transmitter_id: ir2
address: 0x4004
command: 0x8140DFA2
turn_on_action:
transmitter_id: ir3
address: 0x4004
command: 0x8140DFA2
turn_on_action:
transmitter_id: ir4
address: 0x4004
command: 0x8140DFA2
# - platform: template
# name: IR-Send5
# turn_on_action:
# - remote_transmitter.transmit_panasonic:
# transmitter_id: ir5
# address: 0x4004
# command: 0x8140DFA2
# name: IR-Send6
# turn_on_action:
# transmitter_id: ir6
# address: 0x4004
# name: IR-Send7
# turn_on_action:
# transmitter_id: ir7
# address: 0x4004
# name: IR-Send8
# turn_on_action:
# transmitter_id: ir8
# address: 0x4004
- platform: uart
uart_id: uart_485
- platform: uart
uart_id: uart_232
data: "RS232-test"
- id: uart_485
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 18
rx_pin: 8
- id: uart_232
baud_rate: 9600
debug:
direction: BOTH
after:
timeout: 10ms
sequence:
- lambda: UARTDebug::log_string(direction, bytes);
tx_pin: 17
rx_pin: 16
number: 15
mode:
input: true
pullup: true
number: 38
mode:
input: true
pullup: true
number: 39
mode:
input: true
pullup: true
number: 40
mode:
input: true
pullup: true
web_server:
port: 80demo yaml for control Apple TV:
friendly_name: ag8
platformio_options:
type: esp-idf
sdkconfig_options:
encryption:
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
reset_pin: GPIO1
remote_receiver:
pin: 48
rmt_channel: 4
dump: all
remote_transmitter:
- id: ir1
pin: 9
- id: ir2
pin: 10
- id: ir3
pin: 11
- id: ir4
pin: 12
# - id: ir5
# pin: 13
# - id: ir6
# pin: 14
# - id: ir7
# pin: 21
# - id: ir8
# pin: 47
turn_on_action:
- remote_transmitter.transmit_pronto:
transmitter_id: ir1
data: "0000 006C 0022 0002 015B 00AD 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0575 015B 0057 0016 0E6C"
turn_on_action:
transmitter_id: ir2
data: "0000 006C 0022 0002 015B 00AD 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 05CB 015B 0057 0016 0E6C"
turn_on_action:
transmitter_id: ir3
data: "0000 006C 0022 0002 015B 00AD 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 05CB 015B 0057 0016 0E6C"
turn_on_action:
transmitter_id: ir4
data: "0000 006C 0022 0002 015B 00AD 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 05CB 015B 0057 0016 0E6C"
# name: IR-Send5
# turn_on_action:
# address: 0x4004
# name: IR-Send6
# turn_on_action:
# address: 0x4004
# name: IR-Send7
# turn_on_action:
# address: 0x4004
# name: IR-Send8
# turn_on_action:
# address: 0x4004
- platform: uart
uart_id: uart_485
- platform: uart
uart_id: uart_232
data: "RS232-test"
- id: uart_485
baud_rate: 9600
debug:
direction: BOTH
after:
timeout: 10ms
tx_pin: 18
rx_pin: 8
- id: uart_232
baud_rate: 9600
debug:
direction: BOTH
after:
timeout: 10ms
sequence:
tx_pin: 17
rx_pin: 16
number: 15
mode:
input: true
pullup: true
number: 38
mode:
input: true
pullup: true
number: 39
mode:
input: true
pullup: true
number: 40
mode:
input: true
pullup: true
web_server:
port: 80Node: ESP32-S3 chip support 4 channel IR sender work at the same time. here is details by ESPHome webpage:
https://esphome.io/components/remote_transmitter.html
