Full Version: KC868 Uair  external sensor SHT3xD erro
I'm trying to load the Uair with external sensor and got the below error:
19:16:51][C][dallas.temp.sensor:036]:  Update Interval: 60.0s
[19:16:51][C][sht3xd:049]: SHT3xD:
[19:16:51][D][sht3xd:055]:  Error reading serial number
[19:16:51][E][sht3xd:064]:  Communication with SHT3xD failed!
[19:16:51][E][component:082]:  Component sht3xd.sensor is marked FAILED
[19:16:51][C][captive_portal:088]: Captive Portal:
[19:16:51][C][mdns:115]: mDNS:
upload your ESPHome yaml file at here.
platform: ESP32
on_boot:
priority: 200
then:
- lambda: |-
delay(500);
external_components:
- source:
type: git
url: https://github.com/mrtoy-me/esphome-my-components
# ref: main
components: [ sht3xd ]
ota:
- platform: esphome
password: "978e66f878ed5041b830cfb427383c79"
wifi:
ssid: !secret wifi_ssid
captive_portal:
# follow configure use for DS18B20 temperature sensor, SHT30 temperature and humidity sensor. WS2812B RGB LEDs.
sda: 4
scl: 16
frequency: 800khz
timeout: 10ms
# Example configuration entry
one_wire:
pin: GPIO27
# Individual sensors
- platform: dallas_temp
address: 0x840000000d028228 # your DS18B20 address
name: "internal Temperature"
- platform: sht3xd
temperature:
name: "extend Temperature"
humidity:
name: "extend Humidity"
address: 0x44
update_interval: 15s
light:
- platform: fastled_clockless
chipset: WS2812B
pin: GPIO32 # Pin Define connected with LED strip
num_leds: 4 #LEDs number
rgb_order: GRB
effects:
- addressable_rainbow: ##defined 7 effects styles
- addressable_color_wipe:
- addressable_scan:
- addressable_twinkle:
- addressable_random_twinkle:
- addressable_fireworks:
- addressable_flicker:
chipset: WS2812B
pin: GPIO33 # Pin Define connected with LED strip
num_leds: 1 #LEDs number
rgb_order: RGB
effects:
- addressable_scan:
ESPhome Current version: 2024.6.2
can you use my yaml file to test SHT30 sensor.[attachment=5502]
Dallas is not supported in the new esp home version 2024.6.2
Although I used your code and make it computable with the new ESP version and got same error
my means whether SHT30 work well.
if you want use DS18B20, see this topic, our customer have already worked with new ESPHome:
https://www.kincony.com/forum/showthread.php?tid=5939
for the internal temperature its shown but external Nop, it shows 0C temp and 0 Humidity
i think it's i2c extend usb cable pins define problem.  before i am using 4-wires USB mini cable in YouTube video. here is photo:
[attachment=5505]
But now you are using 5-wires. Here is our PCB usb pin define.can you use a multi meter to check whether the vcc,gnd,sda,scl pin is connect correctly. also make sure you have connected with correct USB port of Uair box.
[attachment=5506]
