Full Version: Kc868-AM and sensors
My KC868-AM ports 14,13,5 is not working. I have connected several temperatures to these ports without success. Port 33 is working perfectly.
Is there any reason these ports are not responding
take a photo how you wire, which sensor you can using?
The KC868-AM is reading from only port 13, port 33 is not reading. Ports 5 and 14 connected to one_wire are not displaying anything. Here is the yaml file and screenshoot
  friendly_name: kc868-am-11
  encryption:
    key: "Uc1km2Q/93pAMK9LlN/QZd7Vb+4XcINM1o2Bc/xBfmo="
ota:
  - platform: esphome
    password: "05443423e09db8d6273f7832083d394d"
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  - platform: dht
    pin: 13
    temperature:
      name: "Master Toilet Temperature"
    humidity:
      name: "Master Toilet Humidity"
    update_interval: 10s
  - platform: dht
    pin: 33
    temperature:
      name: "Madam Toilet Temperature"
    humidity:
      name: "Madam Toilet Humidity"
one_wire:
    pin: GPIO5
    pin: GPIO14
take a photo of your board, how you wire.
(09-13-2024, 11:20 AM)admin Wrote: [ -> ]take a photo of your board, how you wire.
Attached, kindly find the photo
take a photo of your sensor, whether the sensor include a pull-up resistance?
