Full Version: attach door sensor to the server
hello admin, i attached the door sensor as the wiring in the photo and also did the programming as given in the picture still there is no response in home assistant
[Image: pxJQg3f][Image: k2wbc5F]
check here: https://www.kincony.com/mqtt-input-modul...stant.html
there have yaml file link, compare with your mqtt syntax.
solved thank you
ok, good.
