Full Version: raspi-config on Server Mini
Hello everyone.
Starting from another thread I realized that I need to run "raspi-config" on my Mini Server in order to make some setting.
On the mini server I installed homeassistant.
I know that to run raspi-config I have to connect my laptop to the Mini server RS485 port.
So, now I have got a USB to RS485 converter to make the hardware connection beetwen my laptop and the Mini server.
My OS on the laptop is Windows 10.
The question is: could anyone show me a step by step guide to make the software connection in order to access the Linux console on the Mini Server and then are able to run raspi-config?
i have seen your screen. because you have already installed home assistant firmware, so you are enter the home assistant control panel command mode.
if you want use Linux console, you need to install Raspberry Pi OS, download link at here: https://www.raspberrypi.com/software/operating-systems/
