Full Version: correct device purchase
Pages: 1 2 3
Kindly I need the example of integration of MQTT not esphome
now KCS not support receive a RF signal feedback to MQTT message.
it only support send a RF signal by MQTT message.
Maybe I expressed myself badly. I have 1 magnetic window sensor 433 I acquire the signal from KCS. With mqtt I would like to create a binary sensor to see when the window is open or closed. Where can I see the code acquired from kcs to be able to create the binary sensor in mqtt?
example:
patform:mqtt
state topic: what do I insert?
playload_on: Receiver detected code in kcs
playload_off: Receiver detected code in kcs
now current KCS version can't feedback RF mqtt message to home assistant. you can create IFTTT by KCS, such as when window is OPEN or CLOSED, THEN relayX ON/OFF. we suggest make logical by ESP32 locally, without home assistant, so that if home assistant broken, logical also will work, because it running by hardware locally.
Pages: 1 2 3
