Full Version: kc868-A8S v2 not working with SIM7600E
HI
SIM7600E module plugged in kc868-A8S v2.0 , running KCS 2.2.2.
  • cannot send message,
  • cannot receive message (crash/reboot when message is received)
  • cannot receive call
  • can only place test phone call
also :
  • the SIM7600E module was successfuly tested with an usb-to-Serial converter and putty. --> the SIM7600 module works fine, can send/receive messages
  • I also tried Tasmota on the kc868, impossible to establish connection to the SIM7600 in serial bridge --> Issue with RX/TX GPIO13/GPIO15 ?
Board Model
KC868_A8S
Software Version
v2.2.2
Build Date
Dec 6 2023 22:18:36
Serial Number
08F9E08BCAD4
Board Time
2024-8-27 11:58:45
Time Zone
UTC+2
Lan IP
Lan Netmask
Lan Gateway
Lan MAC
08:F9:E0:8B:CABig Grin7
Wifi STA IP
192.168.0.21
Wifi MAC
08:F9:E0:8B:CABig Grin4
Tests :
Outgoing
when issuing test;  I got this :
MAKE A CALL ;  OK, my Mobile phone is properly called.
log :
I (121694) SIM7600: call +32xxxxxxxxx
SEND A MESSAGE,  ERROR (no message received on mobile phone)
Log :
I (689066) SIM7600: [1/1] 0011000B912374940999F500007A2654747A0E4ACF416110BD3CA783DAE5F93C7C2E83CCF2771BB41CE26CB84810377501
INCOMING
CALL : nothoing happens, no log
receive   MESSAGE kc868 reboots
log  :
Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
Core  0 register dump:
PC      : 0x400014fd  PS      : 0x00060230  A0      : 0x801629e0  A1      : 0x3ffe52d0
A2      : 0x00000000  A3      : 0xfffffffc  A4      : 0x000000ff  A5      : 0x0000ff00
A6      : 0x00ff0000  A7      : 0xff000000  A8      : 0x00000000  A9      : 0x3ffe5290
A10    : 0x00000000  A11    : 0x3f4e9a1c  A12    : 0x3ffe5514  A13    : 0x3ffaeb58
A14    : 0x00000000  A15    : 0x00000001  SAR    : 0x00000004  EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000  LBEG    : 0x400014fd  LEND    : 0x4000150d  LCOUNT  : 0xffffffff
Backtrace: 0x400014fa:0x3ffe52d0 0x401629dd:0x3ffe52e0 0x4016404d:0x3ffe55f0 0x40176f51:0x3ffe5620 0x4008dd29:0x3ffe5650 0x400e22ca:0x3ffe56a0 0x400e23fc:0x3ffe57f0 0x400e241b:0x3ffe5810 0x400e294f:0x3ffe5a30
ELF file SHA256: 2b1db7d975ea26ea
Rebooting...
I (13) boot: ESP-IDF v4.4.5-dirty 2nd stage bootloader
I (13) boot: compile time 21:27:12
I (13) boot: chip revision: v3.1
I (15) boot.esp32: SPI Speed      : 40MHz
I (20) boot.esp32: SPI Mode      : DIO
I (24) boot.esp32: SPI Flash Size : 4MB
I (29) boot: Enabling RNG early entropy source...
I (34) boot: Partition Table:
I (38) boot: ## Label            Usage          Type ST Offset  Length
I (45) boot:  0 nvs              WiFi data        01 02 00009000 00026000
I (53) boot:  1 phy_init        RF data          01 01 0003f000 00001000
I (60) boot:  2 factory          factory app      00 00 00040000 003b0000
I (68) boot: End of partition table
I (72) esp_image: segment 0: paddr=00040020 vaddr=3f400020 size=104af8h (1067768) map
I (467) esp_image: segment 1: paddr=00144b20 vaddr=3ffb0000 size=0316ch ( 12652) load
I (472) esp_image: segment 2: paddr=00147c94 vaddr=40080000 size=08384h ( 33668) load
I (486) esp_image: segment 3: paddr=00150020 vaddr=400d0020 size=a8454h (689236) map
I (736) esp_image: segment 4: paddr=001f847c vaddr=40088384 size=06ec0h ( 28352) load
I (756) boot: Loaded app from partition at offset 0x40000
I (756) boot: Disabling RNG early entropy source...
I (767) cpu_start: Pro cpu up.
I (768) cpu_start: Starting app cpu, entry point is 0x40081254
I (762) cpu_start: App cpu up.
I (784) cpu_start: Pro cpu start user code
I (784) cpu_start: cpu freq: 240000000
I (784) cpu_start: Application information:
I (788) cpu_start: Project name:    kc868-a-serial
I (794) cpu_start: App version:      v1.0.0-167-gf459a12-dirty
I (800) cpu_start: Compile time:    Dec  6 2023 22:16:06
I (807) cpu_start: ELF file SHA256:  2b1db7d975ea26ea...
I (813) cpu_start: ESP-IDF:          v4.4.5-dirty
I (818) cpu_start: Min chip rev:    v0.0
I (823) cpu_start: Max chip rev:    v3.99
I (827) cpu_start: Chip rev:        v3.1
I (832) heap_init: Initializing. RAM available for dynamic allocation:
I (840) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (845) heap_init: At 3FFC76A0 len 00018960 (98 KiB): DRAM
I (852) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (858) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (864) heap_init: At 4008F244 len 00010DBC (67 KiB): IRAM
I (872) spi_flash: detected chip: generic
I (875) spi_flash: flash io: dio
I (880) cpu_start: Starting scheduler on PRO CPU.
I (0) cpu_start: Starting scheduler on APP CPU.
I (895) main: [APP] Startup..
I (898) main: [APP] Free memory: 214320 bytes
I (903) main: [APP] IDF version: v4.4.5-dirty
I (1175) NVS: init nvs finish.
I (1179) system_api: Base MAC address is not set
I (1179) system_api: read default base MAC address from EFUSE
I (1201) esp_eth.netif.netif_glue: 08:f9:e0:8b:ca:d7
I (1201) esp_eth.netif.netif_glue: ethernet attached to netif
I (5202) eth: Ethernet init
I (5202) wifi station: ESP_WIFI_INIT
I (5202) eth: Ethernet Started
I (5205) wifi:wifi driver task: 3ffd4b18, prio:23, stack:6656, core=0
I (5226) wifi:wifi firmware version: 0f80fa0
I (5227) wifi:wifi certification version: v7.0
I (5227) wifi:config NVS flash: enabled
I (5227) wifi:config nano formating: disabled
I (5232) wifi:Init data frame dynamic rx buffer num: 32
I (5236) wifi:Init management frame dynamic rx buffer num: 32
I (5242) wifi:Init management short buffer num: 32
I (5246) wifi:Init dynamic tx buffer num: 32
I (5250) wifi:Init static rx buffer size: 1600
I (5254) wifi:Init static rx buffer num: 10
I (5258) wifi:Init dynamic rx buffer num: 32
I (5263) wifi_init: rx ba win: 6
I (5266) wifi_init: tcpip mbox: 32
I (5270) wifi_init: udp mbox: 6
I (5274) wifi_init: tcp mbox: 6
I (5278) wifi_init: tcp tx win: 5744
I (5282) wifi_init: tcp rx win: 5744
I (5286) wifi_init: tcp mss: 1440
I (5306) phy_init: phy_version 4670,719f9f6,Feb 18 2021,17:07:07
I (5392) wifi:mode : sta (08:f9:e0:8b:ca:d4)
I (5393) wifi:enable tsf
I (5396) web_server: Starting HTTP Server on port: '80'
I (5404) wifi:new:<6,0>, old:<1,0>, ap:<255,255>, sta:<6,0>, prof:1
I (5400) gpio: GPIO[0]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 1| Intr:0
I (5911) wifi:state: init -> auth (b0)
I (5914) gpio: GPIO[2]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (5917) ntp: tz:UTC-2
I (5919) wifi:I (5918) UDP SERVER: Socket created
state: auth -> init (8a0)
I (5925) UDP SERVER: Socket bound, port 4001
I (5928) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (5920) RF: RCSwitch->nReceiverInterrupt=16 gpio_pin_sel=65536
I (5945) gpio: GPIO[16]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3
I (5955) RF: Start RF receiver
I (5955) uart: queue free spaces: 20
I (5962) gprs: gprs init success.
I (5969) pcf857x: pcf857x init.
eFuse Two Point: NOT supported
eFuse Vref: Supported
I (5975) analog: ---->adc1 thresholdd : 0
I (5979) analog: ---->adc2 thresholdd : 0
I (5984) analog: ---->adc3 thresholdd : 0
I (5989) analog: ---->adc4 thresholdd : 0
I (5993) analog: adc 0 monitor items : 0
I (5998) analog: adc 1 monitor items : 0
I (6003) analog: adc 2 monitor items : 0
I (6007) analog: adc 3 monitor items : 0
I (6012) gpio: GPIO[14]| InputEn: 1| OutputEn: 1| OpenDrain: 1| Pullup: 0| Pulldown: 0| Intr:0
I (8372) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (8373) wifi:state: init -> auth (b0)
I (8379) wifi:state: auth -> assoc (0)
I (8386) wifi:state: assoc -> run (10)
I (8418) wifi:connected with living, aid = 3, channel 6, BW20, bssid = 00:31:92:81:48:e6
I (8419) wifi:security: WPA2-PSK, phy: bgn, rssi: -72
I (8425) wifi:pm start, type: 1
I (8434) wifi:<ba-add>idx:0 (ifx:0, 00:31:92:81:48:e6), tid:0, ssn:0, winSize:64
I (8472) wifi:AP's beacon interval = 102400 us, DTIM period = 1
I (9430) esp_netif_handlers: sta ip: 192.168.0.21, mask: 255.255.255.0, gw: 192.168.0.1
I (9432) wifi station: got ip : 192.168.0.21
I (9717) ifttt: start ifttt task
upload your GSM setting screen in KCS.
(08-27-2024, 10:04 PM)admin Wrote: [ -> ]upload your GSM setting screen in KCS.
please find here below the screenshots.
+324xxxxxxxxx is my mobile phone number (I hide the digits for privacy reasons ;-)
so I can do a test call to my mobile, but anything else fails (outgoing test SMS, incoming control SMS, outgoing notification SMS)
do you have set the SMS service number in your mobile phone. just when the SIM card have normal SMS function when using in your mobile phone?
(08-30-2024, 01:28 PM)admin Wrote: [ -> ]do you have set the SMS service number in your mobile phone. just when the SIM card have normal SMS function when using in your mobile phone?
yes, i tried the exact same hardware combination ( SIM7600E module plugged in kc868-A8S v2.0 ), but  with Tasmota32 instead of  KCS 2.2.2. , and I can manage to send and receive SMS.
so the problem is with  KCS 2.2.2
ok, next week we will test with KC868-A8S v2 board. if have bug, we will feedback to our software team.
we have tested with new KCS firmware V2.2.4 here is download link:
https://www.kincony.com/forum/showthread.php?tid=6600
[attachment=5985]
[attachment=5987]
[attachment=5986]
important: make sure when you enabled GSM, you MUST need click "SAVE" button for reboot. Then you can use TEST with SMS or CALL.
[attachment=5988]
The problem is most likely related to the power supply of the SIM7600E module.
As it is written in the datasheet for this module, it requires 5-10V DC.
However kc868-A8S v2.0 only supplies 4V DC to pin V.
SIM7600E uses a 1084 (or analog) linear regulator in the power circuit with some voltage dropout. As a result, the SIMCOM chip does not have enough power.
This can lead to cyclic reboots and other bad things.
Colleagues from KinCony, can you explain the situation?
A8Sv2  resistance R31 now is 2.26K, you can replace with 3K. Then it will output 5v for GSM module.
Yes, use 5V will be better.
[attachment=6553]
