Full Version: how to use binary sensor send SMS by SIM7600E 4G module in ESPHome
the ESPHome yaml demo made for KinCony KC868-A8S relay board. Actually you can use for any KinCony SIM7600 relay board, just replace 4G module's TXD,RXD define.
[attachment=5887]
[attachment=5888]
[attachment=5889]
here is ESPHome yaml demo:
  platform: ESP32
  sda: 4
  scl: 5
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
# Individual outputs
      pcf8574: pcf8574_hub_out_1
    interlock: [relay6]
    interlock: [relay5]
    interlock: [relay8]
    interlock: [relay7]
# UART configuration for SIM7600E
  tx_pin: GPIO13
  rx_pin: GPIO15
  baud_rate: 115200
  debug:
    direction: BOTH
    dummy_receiver: true
    after:
      timeout: 10ms
    sequence:
      - lambda: UARTDebug::log_string(direction, bytes);
    on_press:
      then:
        - uart.write:
            data: "ATD15381188302;\r\n"  # Replace with the phone number you want to dial
    name: "Send SMS Button"
    on_press:
      then:
        - uart.write:
            data: "AT+CMGF=1\r\n"  # Set SMS to text mode
        - delay: 1s
        - uart.write:
            data: "AT+CMGS=\"15381188302\"\r\n"  # Replace with the recipient's phone number
        - delay: 1s
        - uart.write:
            data: "KinCony-SMS-Sensor\x1A"  # Send the message "KinCony-SMS-Sensor" and terminate with Ctrl+Z
    on_press:
      then:
        - switch.toggle: light3
    on_press:
      then:
        - switch.toggle: light4
    on_press:
      then:
        - switch.toggle: relay5
    on_press:
      then:
        - switch.toggle: relay6
    on_press:
      then:
        - switch.toggle: relay7
    on_press:
      then:
        - switch.toggle: relay8
web_server:
  port: 80
download yaml file:
[attachment=5890]
