(09-04-2024, 11:32 PM)admin Wrote: [ -> ]Here is "KCS" firmware for KinCony KC868-A series (ESP32) board.
How to download and use, online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
v2.2.4 improment:
1. replaced new DHT sensor's driver.
2. fixed MQTT protocol format bug.
Is it possible to know more details on "MQTT Protocol format bug" ?
(10-03-2024, 03:58 AM)admin Wrote: [ -> ]Missing comma
I think it's an extra comma
I see what you're talking about I've had to use a modifier on nodered to fix it.
When are you guys going to enable firmware update via the HTTP page ? Having to use a USB cable is not optimal
maybe in furture will design a new way to update firmware.
Please check the firmware to A32M controller,to correct output number and activate inter lock.
Hi, I installed V2.2.4 firmware n A6 board. I can see all inputs and outputs are working in monitior web page. However, When I short Digital inputs 1-6 with ground, the relays are not turning ON. Could you please help fixing this issue?
(10-10-2024, 07:15 PM)enochjason Wrote: [ -> ]Hi, I installed V2.2.4 firmware n A6 board. I can see all inputs and outputs are working in monitior web page. However, When I short Digital inputs 1-6 with ground, the relays are not turning ON. Could you please help fixing this issue?
it's not a issue. you should create IFTTT command on "IFTTT" webpage, let INPUT trigger with OUTPUT. please see online guide at here:
