Thank you for the Input and Output demo code
Is there a demo code where the inputs and outputs can be read and written to in the same program.
The previous examples allow only inputs or outputs not both together.
you can run this arduino demo "Input-trigger-Output" for KC868-A6:
PCF8574 I2C Digital I/O Expander Example
Made by KinCony IoT: https://www.kincony.com
Description:
This program demonstrates how to use a PCF8574 I2C expander to read input pins and control relays.
It reads input states from a PCF8574 module and controls corresponding relays.
The program initializes the input pins as INPUT and output pins as OUTPUT.
When an input is triggered (LOW), the corresponding relay (output) will activate (LOW).
It also prevents the relays from briefly activating on startup.
Custom I2C pins are defined for SDA and SCL.
License:
You are free to use and modify this code for personal or commercial purposes as long as this
copyright notice remains intact.
// Define custom I2C pins for communication
#define SDA_PIN 4 // Set SDA pin for I2C communication
#define SCL_PIN 15 // Set SCL pin for I2C communication
#include "Arduino.h"
#include "PCF8574.h"
#include <Wire.h>
// Define I2C addresses for the input and output PCF8574 modules
PCF8574 pcf8574_input(0x22); // I2C address for the input expander (change according to your setup)
PCF8574 pcf8574_output(0x24); // I2C address for the output expander (change according to your setup)
// Start serial communication for debugging purposes
delay(1000); // Wait for serial communication to initialize
// Initialize I2C and set custom SDA and SCL pins
Wire.begin(SDA_PIN, SCL_PIN);
// Ensure all relay outputs are set to HIGH (deactivated) before initializing the expander
// This step is to avoid any relay from briefly turning on during setup
for (int i = 0; i < 6; i++) {
pcf8574_output.digitalWrite(i, HIGH);
// Initialize input pins as INPUT
pcf8574_input.pinMode(P0, INPUT);
pcf8574_input.pinMode(P1, INPUT);
pcf8574_input.pinMode(P2, INPUT);
pcf8574_input.pinMode(P3, INPUT);
pcf8574_input.pinMode(P4, INPUT);
pcf8574_input.pinMode(P5, INPUT);
// Initialize output pins as OUTPUT (these control the relays)
pcf8574_output.pinMode(P0, OUTPUT);
pcf8574_output.pinMode(P1, OUTPUT);
pcf8574_output.pinMode(P2, OUTPUT);
pcf8574_output.pinMode(P3, OUTPUT);
pcf8574_output.pinMode(P4, OUTPUT);
pcf8574_output.pinMode(P5, OUTPUT);
// Ensure all outputs (relays) are deactivated at the start (set to HIGH)
// Initialize the PCF8574 modules and check for errors
Serial.print("Init pcf8574_input...");
if (pcf8574_input.begin()) {
Serial.println("OK"); // Input expander initialized successfully
Serial.println("KO"); // Input expander initialization failed
Serial.print("Init pcf8574_output...");
if (pcf8574_output.begin()) {
Serial.println("OK"); // Output expander initialized successfully
Serial.println("KO"); // Output expander initialization failed
// Read input states from the input expander (PCF8574)
uint8_t val[6]; // Array to store input states
val[i] = pcf8574_input.digitalRead(i); // Read the state of each input pin
// Control relays based on the input states
if (val[i] == LOW) {
// If the input is LOW (triggered), activate the corresponding relay (set to LOW)
pcf8574_output.digitalWrite(i, LOW);
// If the input is HIGH (not triggered), deactivate the corresponding relay (set to HIGH)
delay(300); // Small delay to prevent rapid state changes
