Full Version: I2C connector
What is the name of the white I2C connector used on the board if I want to purchase them to make up cables?
Can I use any I2C bus address I choose or is the white connector bus shared with the pcf8574 expanders so I must avoid 0x23, 0x24,0x25 and 0x26?
Thanks!
What is the name of the white I2C connector used on the board if I want to purchase them to make up cables? that called "4pin xh2.54 connector"
Can I use any I2C bus address I choose or is the white connector bus shared with the pcf8574 expanders so I must avoid 0x23, 0x24,0x25 and 0x26? Yes, you are right, need to avoid PCF8574's i2c address.
Excellent. thank you very much for the quick response. I am finding the boards really good work with.
you are welcome.
Could you post the YAML (EspHome) config for using the I2C port for connect a i2c temperature sensor?
suggest use SHT30 i2c temperature sensor, here is yaml: https://esphome.io/components/sensor/sht3xd.html
(09-08-2024, 02:00 PM)admin Wrote: [ -> ]suggest use SHT30 i2c temperature sensor, here is yaml: https://esphome.io/components/sensor/sht3xd.html
Gotcha! Thanks!
