Hello
Can You add "save/restore configuration" option to admin page.
I upgraded firmware and all config was lost.
I had only a few IFTTT rules and one Custom Protocol but writing again 128 IFTT rules and 64 protocols, config all outputs and sensors parameter may be frustrating.
ok, thanks for your suggestion.
Another suggestion: can more sensor connection methods be added to KCS firmware?
For example, ToF sensors with pulse length measurement (HC-SR04).
Or reading measurement result by uart like this
https://pl.aliexpress.com/item/1005005626945766.html
or rotary encoder with up/down counter
do you use home assistant software?
No. I try to integrate controlling and viewing garage doors, gate, doorbell and other device in home in my own home server.
This is my first contact with ESP32 and I didnt use any home assistant software yet.
All logic and automatic is in server, not in KCS.
To learn using home assistant software I need a time.
For now, I'm trying to read the gate opening height. I'm using an analog distance sensor GP2Y0A02 for this.
I would like to use a laser or ultrasonic sensor but the output is of the time-of-flight type and the server-KCS communication is too slow to measure the pulse time.
The drive has a position encoder but it's just a sensor without a counter.
And such options in the firmware would be very helpful.
I think that is easy to implement in IFTTT. U can add a few (3-5) object with type timer and counter.
Timer type object:
KCS have internal timer (ex. for real time). Timer object needs 2 registers and 3 actions defined in IFTTT: reset, start and stop.
"Reset" set both register to 0, "start" write timer value to register 1, "stop" write timer value in register 2.
Reading by host is difference between registers if both was set.
Counter type object is easiest:
Needs 1 register and 3 action: "reset", "count up" and "count down" to set register to 0 and increase/decrease register value.
Have you any guide to flash ESPHome firmware?
I would like to try using it.
Where to connect HC-SR04? It works on 5V and HT ports on 3V.
Maybe it's better to use 433M interface? 433M_T signal as trigger and DATA_R as echo. There is also 5V power supply on connector P2.
How to set PIN parameter?
How define triggers to click, doubleclick and hold on on input.
With setting below
on_click:
- min_length: 50ms
max_length: 350ms
then:
- switch.toggle: output03
- min_length: 1000ms
max_length: 5000ms
then:
- switch.turn_on: output02
on_double_click:
- min_length: 50ms
max_length: 350ms
then:
- switch.turn_on: output01
works single click as expected - toggle output 3
but double click turns on output 1 and toggle output 3 twice
hold input longer then 1 sek turn on output 2 as expected
how to eliminate double toggling output 3 in doubleclick?
