I have a KC868-A16 would it be possible to control a standard computer fan 12v that has PWM ? i know there are some GPIO ports, im assuming i have to configure one of these as PWM, how do i find out which ones they represent on the actual board? The next question is how do i monitor the RPM form the fan and where do i connect and configure it ?
![[Image: sh-07-sensors.jpg]](https://www.kincony.com/images/user-guide/manual/KC868-A16-images/sh-07-sensors.jpg)
gpio32,gpio33,gpio14 support PWM output, but i have not tested, you can try to use it.
(09-19-2024, 11:16 PM)admin Wrote: [ -> ]gpio32,gpio33,gpio14 support PWM output, but i have not tested, you can try to use it.
do you have a schematic for which outputs those are on the pcb?
(09-20-2024, 11:50 AM)admin Wrote: [ -> ]
See this YELLOW region.
Sorry if my message wasnt clear, how do i know which gpio32,gpio33,gpio14 connectors are?
So i was looking for something like HT1 is gpio14, HT2 is gpio32 and HT3 is gpio33 ?
pio33,gpio14
I kind of got it to work, so i can turn on the fan using this config:
But the issue is the fan will only turn on at 100% speed at around halfway of the slider, and i can not control the speed, is there something else i need to do? As currently i can only have it at 0% or 100% speed. Ive tried PWM 1 to 5 only 1 seems to work.
Also in regards to the RPM counter, i dont think the counter is working as its an increasing counter, so i might have to use something else ? I tried counter 2 to 5 same issue. Is there a way to have a RPM counter?
![[Image: pK0RcAO.png]](https://i.imgur.com/pK0RcAO.png)
Sorry, i am not used PWM in Tasmota. i suggest you post your questions to Tasmota forum.
What if i used stock firmware will that work ? or ESPhome?
KCS not support PWM output. you can try to use by ESPHome.
