Full Version: how to turn on relay by SIM7600E 4G module voice call in ESPHome
[attachment=6091]
[attachment=6092]
  encryption:
    key: "YnmQggQsfd7jvFefoMqNCpBtb63RXtotS+mSBQVIhY8="
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
    pin: 15
    inverted: False
    id: relay_1  # Assign ID to relay 1
    pin: 2
    inverted: False
      number: 36
      number: 39
web_server:
  port: 80
# UART configuration for SIM7600E
  tx_pin: GPIO5
  rx_pin: GPIO13
  baud_rate: 115200
interval:
  - interval: 200ms  # Shorten the interval to reduce blocking time
    then:
      - lambda: |-
          static std::string uart_buffer;
          uint8_t c;
          int count = 0;
          const int max_reads = 10;  // Limit the number of bytes read per interval
          while (id(uart_2).available() && count < max_reads) {
            if (id(uart_2).read_byte(&c)) {
              uart_buffer += (char)c;
              count++;
              // Log each received character (optional for debugging)
              ESP_LOGD("UART", "Received: %c", (char)c);
              // Check if we have received the "RING" signal
              if (uart_buffer.find("RING") != std::string::npos) {
                ESP_LOGI("SIM7600", "Incoming call detected, turning on relay 1.");
                id(relay_1).turn_on();  // Turn on relay 1
                uart_buffer.clear();  // Clear the buffer after processing
              // Clear the buffer if it gets too large
              if (uart_buffer.length() > 100) {
ESPHome yaml file for KC868-A2 board download: [attachment=6093]
Hello!
any way to select phone number id? like for gate opener
- registered number > relay 1
- unregistered > relay 2
thank you so much
such as: telephone number A use for turn on relay1
telephone number B use for turn on relay2
exactly, or number A,B...N relay 1, any other unknown number relay 2
thanks
If you want to determine the incoming call number, you can only control the relay after hanging up the phone, is that okay?
yes, I noticed the number appears in the "missed call log" actually I was trying to have the module hanging up the call after the first ring
thanks
also a binary sensor for the RING event would be very useful
yes, but I need to detect the incoming one
I tried with id(ring).publish_state(true); in the lambda but didn't work
(09-26-2024, 11:58 AM)attilhacks Wrote: [ -> ]yes, but I need to detect the incoming one
i don't understand.
I need to receive call, not make call, and binary sensor to detect ring, not placing call
thanks
