Full Version: B16M ESP32-S3 IO pins define
IIC Bus:
SDA:GPIO38
SCL:GPIO39
PCF8575:U57 (relay1-16): i2c address:0x25
PCF8575:U58 (input1-16): i2c address:0x24
DS3231 RTC i2c address: 0x68
1-wire1:GPIO40
1-wire2:GPIO15
1-wire3:GPIO48
1-wire4:GPIO47
free gpio-1:GPIO13
free gpio-2:GPIO14
free gpio-3:GPIO21
Ethernet (W5500) I/O define:
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
interrupt_pin: GPIO2
reset_pin: GPIO1
RS485:
RXD:GPIO8
TXD:GPIO18
Tuya module:
RXD:GPIO17
TXD:GPIO16
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SPI-CS:GPIO9
Are the LEDs hardwired to the mosfet output or are they addressable?  I loaded an ESP32 config and turned on one of the outputs but no led turned.on.
This is my  yaml.
   - id: bus_a
     sda: 38
     scl: 39
     frequency: 400kHz
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  # - platform: uart
  #  uart_id: uart_1
  #  name: "RS485 Button"
  #  data: [0x11, 0x22, 0x33, 0x44, 0x55]
      pcf8574: pcf8574_hub_out_1
Solved - I applied 5vdc to ground and the Digital Output DC connector and now the led lights up and I can measure 5v on the output when turned on.
One issue I ran into is that with the uart config from your sample esphome config, once I flash it, I can no longer flash it again over USB.  The USB connections keeps going up and down. I had to reflash using the KCS flash tool and the v3.4 firmware and start over with ESPHome.
# uart:
#  - id: uart_1
#    baud_rate: 9600
#    debug:
#      direction: BOTH
#      dummy_receiver: true
#      after:
#        timeout: 10ms
#    tx_pin: 18
#    rx_pin: 8
if usb can't work.
1. power off B16M
2. hold on DW (download) button, don't move your finger.
3. power on of B16M
4. release your finger.
5. Then B16M enter bootloader mode. download firmware again.
