09-27-2024, 02:16 AM
friendly_name: b16m
platformio_options:
board_build.flash_mode: dio
board: esp32-s3-devkitc-1
type: esp-idf
encryption:
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
interrupt_pin: GPIO2
reset_pin: GPIO1
- id: bus_a
sda: 38
scl: 39
frequency: 400kHz
- id: 'pcf8574_hub_out_1' # for output channel 1-16
i2c_id: bus_a
address: 0x25
pcf8575: true
- id: 'pcf8574_hub_in_1' # for input channel 1-16
i2c_id: bus_a
pcf8575: true
- id: uart_1
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 18
rx_pin: 8
- platform: uart
uart_id: uart_1
pcf8574: pcf8574_hub_out_1
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
##pull-up resistance on PCB
number: 40
number: 15
number: 48
number: 47
## without resistance on PCB
number: 13
inverted: false
number: 14
inverted: false
number: 21
inverted: false
ads1115:
- address: 0x48
- platform: ads1115
multiplexer: 'A0_GND'
gain: 6.144
resolution: 16_BITS
update_interval: 5s
- platform: ads1115
multiplexer: 'A1_GND'
gain: 6.144
update_interval: 5s
- platform: ads1115
multiplexer: 'A2_GND'
gain: 6.144
update_interval: 5s
- platform: ads1115
multiplexer: 'A3_GND'
gain: 6.144
update_interval: 5s
web_server:
port: 80
