09-27-2024, 02:19 AM
* Pin Definitions:
* - SDA: GPIO 38
* - SCL: GPIO 39
* Delay Time:
#include <Wire.h> // Include the Wire library for I2C communication
#include <PCF8575.h> // Include the PCF8575 library to control the I/O expander
#define SDA 38 // Define the SDA pin
#define SCL 39 // Define the SCL pin
#define DELAY_TIME 200 // Define the delay time in milliseconds
#define I2C_ADDRESS 0x25 // I2C address of the PCF8575 module
pcf8575_R1.begin();
pcf8575_R1.write(i, LOW); // Turn on the relay at pin i (LOW means ON for the relay)
delay(DELAY_TIME); // Wait for DELAY_TIME milliseconds
pcf8575_R1.write(i, HIGH); // Turn off the relay at pin i (HIGH means OFF for the relay)
BIN file (you can use esp32 download tool download to ESP32-S3 with address 0x0 then directly to use) download: [attachment=6110]
