09-27-2024, 02:22 AM
* Description:
* Pin Definitions:
* - SDA: GPIO 38
* - SCL: GPIO 39
* - PCF8575 I2C Address: 0x24
#include "Arduino.h"
#include "PCF8575.h"
// Define I2C pins
#define I2C_SDA 38 // Define SDA pin
#define I2C_SCL 39 // Define SCL pin
// Set I2C address
PCF8575 pcf8575_IN1(0x24); // The I2C address of the PCF8575
Serial.println("KinCony F16 16 channel input state 0:ON 1:OFF");
uint16_t state = 0;
for (int pin = 0; pin < 16; pin++) {
if (pcf8575_IN1.read(pin)) {
delay(500); // Delay 500ms
BIN file (you can use esp32 download tool download to ESP32-S3 with address 0x0 then directly to use) download: [attachment=6112]
