09-27-2024, 02:24 AM
#include <Wire.h> // Library for I2C communication
#include <DFRobot_ADS1115.h> // Library for ADS1115 ADC module
#define SDA_PIN 38
#define SCL_PIN 39
DFRobot_ADS1115 ads(&Wire);
void setup(void)
Wire.begin(SDA_PIN, SCL_PIN);
ads.setAddr_ADS1115(ADS1115_IIC_ADDRESS0); // Address is 0x49
ads.setGain(eGAIN_TWOTHIRDS);
ads.setMode(eMODE_SINGLE);
ads.setRate(eRATE_128);
ads.init();
void loop(void)
if (ads.checkADS1115())
adc0 = ads.readVoltage(0);
Serial.print("A0:");
Serial.print(adc0);
Serial.print("mV, "); // Print the value in millivolts
adc1 = ads.readVoltage(1);
Serial.print("A1:");
Serial.print(adc1);
adc2 = ads.readVoltage(2);
Serial.print("A2:");
Serial.print(adc2);
adc3 = ads.readVoltage(3);
Serial.print("A3:");
Serial.print(adc3);
Serial.println("mV"); // Print the value in millivolts and end the line
else
BIN file (you can use esp32 download tool download to ESP32-S3 with address 0x0 then directly to use) download: [attachment=6114]
