Full Version: [arduino code examples for B16M]-04 RS485 communication test
* RS485 Communication Test
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 8
#define RS485_TXD 18
  while (!Serial);
  // Send a test message
  rs485Serial.println("Hello from KinCony F16!");
  // Wait for a short period
    String receivedMessage = "";
      char c = rs485Serial.read();
      receivedMessage += c;
    // Print the received message
    Serial.print("Received: ");
  delay(2000);
arduino ino file download:  [attachment=6115]
BIN file (you can use esp32 download tool download to ESP32-S3 with address 0x0 then directly to use) download:  [attachment=6116]
