09-27-2024, 02:33 AM
* received from a client.
* Hardware connections:
* - CLK: GPIO42
* - MOSI: GPIO43
* - MISO: GPIO44
* - CS: GPIO41
* - RST: GPIO1
* - INT: GPIO2
* Subnet Mask: 255.255.255.0
* Gateway: 192.168.3.1
* DNS: 192.168.3.1
#include <SPI.h>
#include <Ethernet.h>
#define W5500_CS_PIN 41
#define W5500_RST_PIN 1
#define W5500_INT_PIN 2
#define W5500_CLK_PIN 42
#define W5500_MOSI_PIN 43
#define W5500_MISO_PIN 44
IPAddress ip(192, 168, 3, 55); // Static IP address
IPAddress subnet(255, 255, 255, 0); // Subnet mask
IPAddress gateway(192, 168, 3, 1); // Default gateway
IPAddress dns(192, 168, 3, 1); // DNS server address
EthernetServer server(4196);
while (!Serial) {
digitalWrite(W5500_RST_PIN, LOW); // Reset the W5500 module
delay(100); // Wait for reset to complete
Ethernet.init(W5500_CS_PIN);
Serial.print("IP Address: ");
server.begin();
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
server.write(c);
client.stop();
BIN file (you can use esp32 download tool download to ESP32-S3 with address 0x0 then directly to use) download: [attachment=6124]
