Full Version: [arduino code examples for B16M]-09 how to communication with Tuya WiFi module
* Functionality:
#include <HardwareSerial.h>
HardwareSerial tuyaSerial(1);
#define TXD_PIN 16
#define RXD_PIN 17
#define BAUD_RATE 9600
  if (tuyaSerial.available()) {
      if (bytesRead < 7) {
          if (bytesRead >= 7) break;
        return;
        Serial.print(" ");
      Serial.println();
        Serial.print(" ");
      Serial.println();
  // Delay to avoid CPU overuse
  delay(100);
    switch(packet[2]) {
      case 0x00:
        break;
      default:
        break;
    Serial.print(packet[i], HEX);
    Serial.print(" ");
  Serial.println();
arduino ino file download:  [attachment=6125]
BIN file (you can use esp32 download tool download to ESP32-S3 with address 0x0 then directly to use) download: [attachment=6126]
