Full Version: [arduino code examples for B16M]-10 Print TEXT on SSD1306 OLED displayer
* - SCL (clock) on pin IO39
* - SDA (data) on pin IO38
// Initialize the display using the software I2C method (SCL = IO39, SDA = IO38)
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0,  39, 38, U8X8_PIN_NONE);  // Screen rotation: U8G2_R0
void page1() {
  u8g2.begin();
  do {
    page1();
arduino ino file download:  [attachment=6127]
BIN file (you can use esp32 download tool download to ESP32-S3 with address 0x0 then directly to use) download: [attachment=6128]
I want the OLED display to work with esphome is this possible?
I have 2 sensors wired float and wired submersible sensor so the reading to be displayed on the OLED screen
sure, it's ok, do you using B16M controller?
