10-13-2024, 10:15 AM
Hi
if i update the boards A64 / A128 the outputs does not retain their status so if i have switch-1 on and reboot the switch-1 goes off
i run ESPHome true Home Assistant and run the automations true node-red is there a possibility to have it retain the previous state before reboot or update
Also i want to use my ethernet but it wont connect
Thanks in advance
Sijmen
friendly_name: Kincony KC868-A64-RK
encryption:
key: "xxxx"
ota:
password: "xxx"
platform: esphome
#wifi:
# ssid: !secret wifi_ssid
# password: !secret wifi_password
# # Enable fallback hotspot (captive portal) in case wifi connection fails
# ap:
# ssid: "Kincony-Kc868-A64-Rk"
# password: !secret wifi_ap
#captive_portal:
# Example configuration entry
- id: bus_a
sda: 5
scl: 16
frequency: 400kHz
- id: bus_b
sda: 15
scl: 4
frequency: 400kHz
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
manual_ip:
static_ip: 20.20.20.192
gateway: 20.20.20.1
subnet: 255.255.255.0Thanks in advance
Sijmen
