Full Version: Max PWM frequency
(10-21-2024, 01:44 PM)admin Wrote: [ -> ]about KC868-D16, it's output 0-10v
That's the problem Smile . It is not dimming the 12V just outputting some control PWM signal in the 0-10V range which another product would need to receive. That "another product" is the question then. What could handle 20kHz and a couple of Amperes of load, do you have any concrete examples?
Dimmable LED PSUs are expensive and I'd need one for each output of which I have around 20 so it's not feasible. The LED drivers (without PSU) which I could find are only capable of handling ~1.5kHz max, which is not 20kHz which I'd need so they are not a solution either.
Do you think if KC868-AP remove the PCA9685 , use ESP32 pins connect to driver IC directly will be ok?
how many channel you want? maybe ESP32-S3 not have enough GPIOs for PWM output.
(10-22-2024, 12:13 AM)admin Wrote: [ -> ]Do you think if KC868-AP remove the PCA9685 , use ESP32 pins connect to driver IC directly will be ok?
Yes, removing the PCA9685 for the outputs and letting the ESP32 output the PWM signal which is then "amplified" by a MOSFET driver IC connected to a beefier, low Rds_ON MOSFET should work since this is exactly my current setup. If the driver IC and MOSFETs are properly chosen, it should not get warmer than 30-35 °C so no heatsink is necessary.
I created the PCB I currently use myself. It works but I'm looking for a more "industrial-grade" (e.g. din rail mountable) solution or at least something which was designed by people who are PCB experts and not hobbyists like me. Wink
I think 10 or 16 channels per board should be fine. If someone needs more output (like me), they could buy multiple boards.
Here (https://quinled.info/quinled-an-penta-di...are-guide/) is the only board I could find which on paper should satisfy my needs but it is not available as a pre-made board. On the page I linked there is schematics and concrete component list (orderable from LCSC) which might help if you decide to design a new Kincony board for filling this market gap. Smile
which MOSFET driver IC model you think is ok?
(10-22-2024, 11:09 AM)admin Wrote: [ -> ]which MOSFET driver IC model you think is ok?
I use this driver IC and this MOSFET. The Quinled board uses this driver IC and this MOSFET. I have no experience with the latter but should be also fine.
Just wanted to put in my support for a direct driven mosfet product offering, even with less outputs. (Not going through a expander IC) Having more control over the PWM frequency is very much needed for a lot of applications.
because B16M mosfet contrl by PCF8575, not by ESP32-S3's pin directly.
