10-22-2024, 01:01 AM
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#define SCK 11
#define MISO 10
#define MOSI 12
#define CS 13
void readFile(fs::FS &fs, const char * path){
File file = fs.open(path);
if(!file){
return;
while(file.available()){
file.close();
void writeFile(fs::FS &fs, const char * path, const char * message){
if(!file){
return;
if(file.print(message)){
file.close();
void appendFile(fs::FS &fs, const char * path, const char * message){
if(!file){
return;
file.close();
void deleteFile(fs::FS &fs, const char * path){
if(fs.remove(path)){
void testFileIO(fs::FS &fs, const char * path){
static uint8_t buf[512];
size_t len = 0;
uint32_t start = millis();
uint32_t end = start;
if(file){
len = file.size();
size_t flen = len;
start = millis();
while(len){
size_t toRead = len;
if(toRead > 512){
toRead = 512;
file.read(buf, toRead);
len -= toRead;
end = millis() - start;
file.close();
if(!file){
return;
size_t i;
start = millis();
for(i=0; i<2048; i++){
file.write(buf, 512);
file.close();
void setup(){
if (!SD.begin(CS,spi,80000000)) {
return;
if(cardType == CARD_NONE){
return;
if(cardType == CARD_MMC){
Serial.println("MMC");
} else if(cardType == CARD_SD){
Serial.println("SDSC");
} else if(cardType == CARD_SDHC){
Serial.println("SDHC");
Serial.println("UNKNOWN");
delay(2000);
deleteFile(SD, "/hello.txt");
readFile(SD, "/hello.txt");
testFileIO(SD, "/test.txt");
void loop(){
}arduino ino file download: [attachment=6259]
BIN file (you can use esp32 download tool download to ESP32-S3 with address 0x0 then directly to use) download: [attachment=6260]
