Full Version: A128 and B32Pro
Hello. I also ask for help.
I have 1 piece of A128 and B32Pro with AK.
I want to make one of these modules keep the output on as long as I press an input?
I also tried with (KCS firmware v2 and v1)
can i do this with these modules?
can you take an example? such as if you want A128's digital input TOGGLE H32B Pro's relay output?
when input 1 from A128 is ok autput 1 A128 on and when I release input 1 (release from GNG) autput 1 off
Yes, download KCS firmware: https://www.kincony.com/forum/showthread.php?tid=3504
set IFTTT ,
INPUT1=ON, OUTPUT1=ON; INPUT1=OFF, OUTPUT1=OFF;
INPUT2=ON, OUTPUT2=ON; INPUT2=OFF, OUTPUT2=OFF;
INPUT3=ON, OUTPUT3=ON; INPUT3=OFF, OUTPUT3=OFF;
How do I write the "INPUT1=ON, OUTPUT1=ON; INPUT1=OFF, OUTPUT1=OFF;" command in IFTTT in below screen capture?
Thank you
we have two way for this function:
1. config by KCS webpage, using KCS v1 firmware.
2. configy by ESPHome, using ESPHome firmware.
if use by KCS, just set as this photo at "INPUT" webpage:
[Image: input-bind-output.png]
here is details, suggest you see this online guide firstly: https://www.kincony.com/kcs-firmware-esp32-board.html
