Full Version: A16 kcs v2.2.4 delay sometime not working
I had set the output with type delay(30) for all output, sometimes some relay will not turn off after the 3 secs and will stay on.
You can try setup as above, then turn on one by one for all relays, some relay/output will stay on after 3 secs.
If you do it slowly, it is ok, if you turn on the output one by one fast example relay 1-16, some output will stay on
Please help to look into this. Thank you.
can you test with the newest firmware, KCS v2.2.6 , here is download link: https://www.kincony.com/forum/showthread.php?tid=6931
