Full Version: Temp Sensors
Can anyone tell me if the KC868-AIO supports more than two temp sensors?
From the videos it looks like it has two GPIO ports for temp sensors, but not sure if that means only can use two?
Or can multiple temp sensors be hooked to each port ?
We have a project that needs 4 temp sensors. Would we have to use analog temp sensors if we needed more than 2?
Thanks!
About 4 temperature sensor, it's OK, because home assistant support use one GPIO for multi sensors, such as DS18B20. we have tested, 12pcs of DS18B20 work with one GPIO also is work well. You just config it by ESPHome.
Note: next time not post multi thread with one question.
