Full Version: KC868-A8 board esphome + Tuya
Hello. I'm configuring the KC868-A8 board with Esphome and the Tuya license. However, I found some errors and would like to share them for a possible solution. KC868-A8 board esphome + Tuya
It's giving an error that I don't know exactly. error image attached.
# Basic Config
  platform: ESP32
external_components:
  - source:
      type: git
      url: https://github.com/hzkincony/esphome-tuya-iot
      ref: v1.2.0
  baud_rate: 0
  encryption:
    key: "It2KB/xCg0EuwXMc1KyiTXRTSjr0hdQXmxQXnwIVmOE="
ota:
  - platform: esphome
    password: "70604538ddb4bdb4362c2d63114dfb1d"
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Add web server
web_server:
  port: 80
  auth:
    username: admin
    password: "admin"
text_sensor:
  - platform: homeassistant
    name: "Casa Inteligente"
    entity_id: input_text.test
time:
# Individual outputs
      pcf8574: pcf8574_hub_out_1
    restore_mode: RESTORE_DEFAULT_ON
    on_turn_on:
      - lambda: !lambda |-
          id(tuya_iot_component).property_report("output1", true);
    on_turn_off:
          id(tuya_iot_component).property_report("output1", false);
    on_turn_on:
          id(tuya_iot_component).property_report("output2", true);
    on_turn_off:
          id(tuya_iot_component).property_report("output2", false);
    on_turn_on:
          id(tuya_iot_component).property_report("output3", true);
    on_turn_off:
          id(tuya_iot_component).property_report("output3", false);
    on_turn_on:
          id(tuya_iot_component).property_report("output4", true);
    on_turn_off:
          id(tuya_iot_component).property_report("output4", false);
    on_turn_on:
          id(tuya_iot_component).property_report("output5", true);
    on_turn_off:
          id(tuya_iot_component).property_report("output5", false);
    on_turn_on:
          id(tuya_iot_component).property_report("output6", true);
    on_turn_off:
          id(tuya_iot_component).property_report("output6", false);
    on_turn_on:
          id(tuya_iot_component).property_report("output7", true);
    on_turn_off:
          id(tuya_iot_component).property_report("output7", false);
    on_turn_on:
          id(tuya_iot_component).property_report("output8", true);
    on_turn_off:
          id(tuya_iot_component).property_report("output8", false);
    on_press:
      then:
        - switch.toggle: light1
    on_press:
      then:
        - switch.toggle: light2
    on_press:
      then:
        - switch.toggle: light3
    on_press:
      then:
        - switch.toggle: light4
    on_press:
      then:
        - switch.toggle: light5
    on_press:
      then:
        - switch.toggle: light6
    on_press:
      then:
        - switch.toggle: light7
    on_press:
      then:
        - switch.toggle: light8
      number: 32
      number: 33
one_wire:
    pin: GPIO14
  - platform: dallas_temp
    address: 0x06136e7e1f64ff28  # Endereço específico do sensor
    accuracy_decimals: 1  # Precisão do sensor em casas decimais
    update_interval: 30s  # Intervalo de atualização dos dados
  - platform: dht
    pin: GPIO13  # Ajuste para o pino que você está usando
    model: DHT22  # Substitua pelo modelo do seu sensor (DHT11, DHT22, AM2301, etc.)
    temperature:
    humidity:
    update_interval: 30s  # Ajuste o intervalo de atualização conforme necessário
tuya_iot:
  product_id: xxx
  device_id: xxx
  device_secret: xxx
  region: us # eu, us, eus, weu, in, cn
  # eu: Central Europe Data Center
  # us: US West Data Center
  # eus: US East Data Center
  # weu: Western Europe Data Center
  # in: India Data Center
  # cn: Chinese Data Center
  on_event:
    - event_name: property/set
      then:
              // Append the required switch in switch_map to respond to commands issued by Tuya.
              static std::map<float, switch_::Switch*> switch_map {
                { 1, id(light1) },
                { 2, id(light2) },
                { 3, id(light3) },
                { 4, id(light4) },
                { 5, id(light5) },
                { 6, id(light6) },
                { 7, id(light7) },
                { 8, id(light8) },
tuya_iot:
product_id: xxx
device_id: xxx
device_secret: xxx
in your code, xxx means replace with your tuya license information.
Friend, I know that, I did the procedure on the license, however, that is not the problem. I posted the image of the error next to it. I would really like your help. ERROR --->
src/esphome/components/tuya_iot/tuya_iot_component.cpp: In the lambda function:
src/esphome/components/tuya_iot/tuya_iot_component.cpp:167:96: error: Invalid initialization of reference of type 'const json_parse_t&' {aka 'const std::function<bool(ArduinoJson6185_D1::ObjectRef)>&'} of the expression of type 'esphome::tuya_iot::TuyaIotComponent:Confusedubscribe_json(const string&, const mqtt_json_callback_t&, uint8_t)::<lambda(const string&, const string&)>::<lambda(ArduinoJson::JsonObject)>'
json::parse_json(payload, [topic, callback](JsonObject root) { callback(topic, root); });
In the file included at src/esphome/core/string_ref.h:10, ....
post your whole yaml file at here or send to email: web@kincony.com
[anexo=6367]
(11-05-2024, 12:20 AM)administrador Wrote: [ -> ]publique seu arquivo yaml completo aqui ou envie para o e-mail: web@kincony.com
Vai o txt.
Because ESPHome have updated, so we updated tuya component also.
just use new version will be ok.
- source:
type: git
ref: v1.2.1
switch to v1.2.1 , not use v1.2.0
It worked, however, now I can't access the KC-868-A8 device. The lan port does not activate, nor does the wifi connect.
connect ethernet cable with your router, after download re power on of your board, check in your router, whether can find KC868-A8 board.
I did this procedure, I even use mikrotik router, I even check the logs. Both via WiFi and wired, they don't work. Even the LAN port LED doesn't light up
now your yaml is config for ethernet, if you want config by wifi, need modify the yaml. you can modify change for wifi , test it. if also can't work, take a video send to us.
