Full Version: Digital input 11.2v
I am new here... I have uploaded the digital input code to the KC868-a8s-v2 from the knowledge base. SEE BELOW. When I test the voltage on the input with nothing connected, there is 11.2v read from all of the inputs.
Why is this happening?
How do I use the digital inputs?
#include "Arduino.h"
#include "PCF8574.h"
// Set i2c address
PCF8574 pcf8574(0x22,4,5);// 0x22 is address, IO4 is SDA  IO5 is SCL
unsigned long timeElapsed;
//    pcf8574.pinMode(P0, OUTPUT);
pcf8574.pinMode(P0, INPUT);
pcf8574.pinMode(P1, INPUT);
pcf8574.pinMode(P2, INPUT);
pcf8574.pinMode(P3, INPUT);
pcf8574.pinMode(P4, INPUT);
pcf8574.pinMode(P5, INPUT);
pcf8574.pinMode(P6, INPUT);
pcf8574.pinMode(P7, INPUT);
    if (pcf8574.begin()){
        Serial.println("OK");
    }else{
        Serial.println("KO");
uint8_t val5 = pcf8574.digitalRead(P4);
uint8_t val6 = pcf8574.digitalRead(P5);
uint8_t val7 = pcf8574.digitalRead(P6);
uint8_t val8 = pcf8574.digitalRead(P7);
    delay(300);
you can short digital with GND, when input 0V means "key pressed".
now you input 11.2v = NOT trigger.
