Full Version: Configure presence sensor settings in ESPHome
Hello, can I configure settings for your presence sensor in esphome:
https://www.aliexpress.com/item/1005006030673158.html
Or should I configure using remote?
Also, which presence sensor component does it use? LD2410? Thank you.
just dry contact output. so you can use BINARY SENSOR in ESPHome.
(11-28-2024, 08:07 AM)admin Wrote: [ -> ]just dry contact output. so you can use BINARY SENSOR in ESPHome.
Understood. Thank you.
Hi, can you please share how to configure sensor using remote control. I could not find a guide to set the sensor with the new remote that I received with the sensors. Thanks
here is Presence-Sensor-Remote-Control-User-Manual PDF.
[attachment=7305]
Thanks a lot for the help.
