Full Version: [arduino code examples for F24]-12 How to control one relay
* This program controls a 24-channel relay board via two PCF8575 I/O expanders.
* It toggles relay 24 every 2 seconds and prints its status via the serial port.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* Relay 24 is controlled through the first PCF8575 (I2C_ADDRESS_R1).
#define SDA 8            // Define the SDA pin
#define SCL 18           // Define the SCL pin
#define TOGGLE_DELAY 2000  // Define the toggle delay time (2 seconds)
// Set I2C addresses of the PCF8575 modules
#define I2C_ADDRESS_R1 0x25 // I2C address of the first PCF8575 module (for relays 9-24)
#define I2C_ADDRESS_R2 0x26 // I2C address of the second PCF8575 module (for relays 1-8)
PCF8575 pcf8575_R1(I2C_ADDRESS_R1); // Create a PCF8575 object for the first module (for relays 9-24)
PCF8575 pcf8575_R2(I2C_ADDRESS_R2); // Create a PCF8575 object for the second module (for relays 1-8)
bool relay24State = HIGH; // Initialize relay 24 state to OFF (assuming HIGH is OFF)
  // Initialize serial communication for debugging
  Serial.println("PCF8575 Relay 24 Toggle Program: Starting...");
  // Initialize the PCF8575 modules
  pcf8575_R1.begin();
  pcf8575_R2.begin();
  // Ensure that all relays are turned off initially (set all pins HIGH)
    pcf8575_R1.write(i, HIGH); // Set relays 9-24 to OFF (assuming HIGH means OFF for relays)
    pcf8575_R2.write(i, HIGH); // Set relays 1-8 to OFF (assuming HIGH means OFF for relays)
  // Toggle relay 24 state (relay 24 corresponds to pin 15 on pcf8575_R1)
  relay24State = !relay24State; // Toggle the state
  pcf8575_R1.write(15, relay24State); // Write the new state to relay 24
  // Print the current state of relay 24 to the serial port
  if (relay24State == LOW) {
    Serial.println("Relay 24 is ON");
    Serial.println("Relay 24 is OFF");
  // Wait for 2 seconds before toggling again
  delay(TOGGLE_DELAY);
arduino ino file download:
[attachment=6537]
