Full Version: Door Access Control System
    As per the link below,
       https://www.kincony.com/remote-access-co...ution.html
I found out that KC868 relay controllers can be configured to be used as door access control system. But, in that solution, I only found out ( or may be I missed out ) magnetic door locks and exit buttons used with controller.
I wonder if there are any possible solutions to use proximity card reader (with Weigand interface, later, convert to RS485 from Weigand) with the relay controllers. Could you please suggest me a way to integrate door access control system to KINCONY relay controller? Or, if you have any recommended card readers of any kinds or KINCONY's own card reader models, please enlighten me. I would like to integrate door access control system in my smart home project. Thanks in advance.
you can check with this video tour: https://youtu.be/v-Vs4NbJy5k
Thank you for your support, I have watched the video. I've found that I can find a solution for door access system with that Wiegand keypad card reader supported from ESPhome.
ok
