Full Version: KC868-server automations
Hello, I have updated my HA OS to 13.2. I'm able to control the binary.inputs and switch.outputs.
All the automations i have created have disappeared in my Home Assistant.
Automation and scenes have been separated, now there is automations and scenes separately.
I tried to create new automations on KC868-Server, but it doesn't allow recognise my binary.inputs and switch.outputs when trying to create automations.
Looks like HA doesn't recognise the 'state' changes for binary inputs and switch outputs.
post your config yaml at here.
#frontend:
#themes: !include_dir_merge_named themes
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 172.30.33.0/24
# Example configuration.yaml entry
  # Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
automation: !include automations.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
mqtt:
  - name: 'output-1'
    unique_id: output-1
    state_topic: 'server/a767350037679772fcb2/state'
    command_topic: 'server/767350037679772fcb2/set'
    payload_on:  '{"relay1":{"on":1}}'
    payload_off:  '{"relay1":{"on":0}}'
    state_on: 1
    state_off: 0
  - name: 'output-2'
    unique_id: output-2
    state_topic: 'server/767350037679772fcb2/state'
    payload_on:  '{"relay2":{"on":1}}'
    payload_off:  '{"relay2":{"on":0}}'
    value_template: '{{ value_json.relay2.on }}'
    state_on: 1
    state_off: 0
  - name: 'output-3'
    unique_id: output-3
    payload_on:  '{"relay3":{"on":1}}'
    payload_off:  '{"relay3":{"on":0}}'
    value_template: '{{ value_json.relay3.on }}'
    state_on: 1
    state_off: 0
  - name: 'output-4'
    unique_id: output-4
    payload_on:  '{"relay4":{"on":1}}'
    payload_off:  '{"relay4":{"on":0}}'
    value_template: '{{ value_json.relay4.on }}'
    state_on: 1
    state_off: 0
  - name: 'output-5'
    unique_id: output-5
    payload_on:  '{"relay5":{"on":1}}'
    payload_off:  '{"relay5":{"on":0}}'
    value_template: '{{ value_json.relay5.on }}'
    state_on: 1
    state_off: 0
  - name: 'output-6'
    unique_id: output-6
    payload_on:  '{"relay6":{"on":1}}'
    payload_off:  '{"relay6":{"on":0}}'
    value_template: '{{ value_json.relay6.on }}'
    state_on: 1
    state_off: 0
  - name: 'output-7'
    unique_id: output-7
    payload_on:  '{"relay7":{"on":1}}'
    payload_off:  '{"relay7":{"on":0}}'
    value_template: '{{ value_json.relay7.on }}'
    state_on: 1
    state_off: 0
  - name: 'output-8'
    unique_id: output-8
    payload_on:  '{"relay8":{"on":1}}'
    payload_off:  '{"relay8":{"on":0}}'
    value_template: '{{ value_json.relay8.on }}'
    state_on: 1
    state_off: 0
  - name: 'output-9'
    unique_id: output-9
    payload_on:  '{"relay9":{"on":1}}'
    payload_off:  '{"relay9":{"on":0}}'
    value_template: '{{ value_json.relay9.on }}'
    state_on: 1
    state_off: 0
  - name: 'output-10'
    unique_id: output-10
    payload_on:  '{"relay10":{"on":1}}'
    payload_off:  '{"relay10":{"on":0}}'
    value_template: '{{ value_json.relay10.on }}'
    state_on: 1
    state_off: 0
  - name: 'output-11'
    unique_id: output-11
    payload_on:  '{"relay11":{"on":1}}'
    payload_off:  '{"relay11":{"on":0}}'
    value_template: '{{ value_json.relay11.on }}'
    state_on: 1
    state_off: 0
  - name: 'output-12'
    unique_id: output-12
    payload_on:  '{"relay12":{"on":1}}'
    payload_off:  '{"relay12":{"on":0}}'
    value_template: '{{ value_json.relay12.on }}'
    state_on: 1
    state_off: 0
  - name: 'output-13'
    unique_id: output-13
    payload_on:  '{"relay13":{"on":1}}'
    payload_off:  '{"relay13":{"on":0}}'
    value_template: '{{ value_json.relay13.on }}'
    state_on: 1
    state_off: 0
  - name: 'output-14'
    unique_id: output-14
    payload_on:  '{"relay14":{"on":1}}'
    payload_off:  '{"relay14":{"on":0}}'
    value_template: '{{ value_json.relay14.on }}'
    state_on: 1
    state_off: 0
  - name: 'output-15'
    unique_id: output-15
    payload_on:  '{"relay15":{"on":1}}'
    payload_off:  '{"relay15":{"on":0}}'
    value_template: '{{ value_json.relay15.on }}'
    state_on: 1
    state_off: 0
  - name: 'output-16'
    unique_id: output-16
    payload_on:  '{"relay16":{"on":1}}'
    payload_off:  '{"relay16":{"on":0}}'
    value_template: '{{ value_json.relay16.on }}'
    state_on: 1
    state_off: 0
  - name: 'input-1'
    unique_id: input-1
    value_template: '{{ value_json.input1.on }}'
    payload_on: 1
    payload_off: 0
  - name: 'input-2'
    unique_id: input-2
    value_template: '{{ value_json.input2.on }}'
    payload_on: 1
    payload_off: 0
  - name: 'input-3'
    unique_id: input-3
    value_template: '{{ value_json.input3.on }}'
    payload_on: 1
    payload_off: 0
  - name: 'input-4'
    unique_id: input-4
    value_template: '{{ value_json.input4.on }}'
    payload_on: 1
    payload_off: 0
  - name: 'input-5'
    unique_id: input-5
    value_template: '{{ value_json.input5.on }}'
    payload_on: 1
    payload_off: 0
  - name: 'input-6'
    unique_id: input-6
    value_template: '{{ value_json.input6.on }}'
    payload_on: 1
    payload_off: 0
  - name: 'input-7'
    unique_id: input-7
    value_template: '{{ value_json.input7.on }}'
    payload_on: 1
    payload_off: 0
  - name: 'input-8'
    unique_id: input-8
    value_template: '{{ value_json.input8.on }}'
    payload_on: 1
    payload_off: 0
  - name: 'h32p-input-1'
    unique_id: h32p-input-1
    state_topic: 'relay32/dbc92afcaf7a9902eacb08f5/state'
    payload_on: 1
    payload_off: 0
  - name: 'h32p-input-2'
    unique_id: h32p-input-2
    payload_on: 1
    payload_off: 0
  - name: 'h32p-input-3'
    unique_id: h32p-input-3
    payload_on: 1
    payload_off: 0
  - name: 'h32p-input-4'
    unique_id: h32p-input-4
    payload_on: 1
    payload_off: 0
  - name: 'h32p-input-5'
    unique_id: h32p-input-5
    payload_on: 1
    payload_off: 0
  - name: 'h32p-input-6'
    unique_id: h32p-input-6
    payload_on: 1
    payload_off: 0
  - name: 'analog-1'
    unique_id: analog-1
    unit_of_measurement: 'v'
    value_template: '{{ value_json.analog1.value }} '
  - name: 'analog-2'
    unique_id: analog-2
    value_template: '{{ value_json.analog2.value }} '
  - name: 'analog-3'
    unique_id: analog-3
    value_template: '{{ value_json.analog3.value }} '
  - name: 'analog-4'
    unique_id: analog-4
    value_template: '{{ value_json.analog4.value }} '
take a photo of your error information screen.
When I create automation or scripts both don't appear in the UI list of automations or scripts after I have created them. The run button is greyed out and there are not errors.
Create it from your side and share the process. The objective is to switch on/off any of the 16 outputs when any of the 8 binary inputs are switch on/off. Or create a script or automation to switch on output 1 when binary input 1 is switched on.
take a video of your problem. so that i can understand and do as your step.
