Full Version: 0-10v in analog input
please tell me, if I connect a voltage over 10v to the analog input 0-5v, will the port (pin) break? Do I understand correctly that at a voltage above 5v, the value will be 4095?
if you input 10v will not broken board, but the input port design for MAX 5v for user.
(12-09-2024, 08:16 AM)admin Wrote: [ -> ]if you input 10v will not broken board, but the input port design for MAX 5v for user.
that is, if 10v is connected for more than 24 hours, and then 3.3v is connected, will the readings be correct?
you can test it.
