Full Version: KBOX-Pad for Windows PC or Windows Tablet 10 inch
Dear Admin
I download the Application from your Web site KBOX-Pad for Windows PC or Windows Tablet 10 inch.
When I ran the application all the relays are work well but I don't see AI1 and AI2.
There is NO indication at all.
See screenshot below
[attachment=105]
When I run your older Application, I can see the data.
[attachment=106]
Please advise why the new application is not working?
Regards
Subas
you have not enable "AutoReport ON" function, click the button, before click , set the "Parameter" for value of temperature and analog and the auto report inteval time .
(12-13-2020, 11:32 AM)admin Wrote: [ -> ]you have not enable "AutoReport ON" function, click the button, before click , set the "Parameter" for value of temperature and analog and the auto report inteval time .
I am having same issue with Analog inputs and temperature inputs using KBOX-Pad.  Auto report is on and parameters set but no values showing on dashboard?
James
take photo of your KBOX-PAD screen. whether have see "COL_Connect OK" in bottom line?
I tried pasting a screen print.  That did not work and I deleted that post.
"COL_connect OK" shows on KBOX-pad screen.
do you means: digital input have feedback, that anaog input is no data display?
(04-09-2021, 11:23 PM)admin Wrote: [ -> ]do you means: digital input have feedback, that anaog input is no data display?
Problem is no data display of analog inputs.  Sometimes temperature does not display.
(Digital inputs and digital output commands display are ok)
James
because analog input and temperature data updated when the preset threshold is exceeded. I think you can set a smaller value for threshold. such as analog is 0.1V, temperature is 0.1℃
(04-11-2021, 04:43 AM)admin Wrote: [ -> ]because analog input and temperature data updated when the preset threshold is exceeded. I think you can set a smaller value for threshold. such as analog is 0.1V, temperature is 0.1℃
I am revisiting this issue because I would like to use KBOX-Pad on my PC.  The problem is that I do not receive or see any analog inputs (Connect is "OK").
I noticed that the KBOX-Pad.INI file has no definitions for Analog inputs.  This is a copy of the file:
[NetWork_Config]
IP=192.168.1.XX
Port=4196
;change for your relay controller's IP and Port
COL_IP=192.168.1.XXX
COL_Port=4196
;change for your logical controller's IP and Port
[Title_Config]
Software_title=KC868 Smart Home Control System
CopyRight=Made By KinCony & JAC
[Device_Config]
Light1=IR Beams Reset
Light2=Motions Reset
Light3=Test Valve 1
Light4=Linear Actuator
Light5=RF Lamp 1
Light6=lamp
Light7=power
Light8=screen
Light9=lock
Light10=fan
Light11=garage
Light12=heater
Light13=kettle
Light14=desk lamp
Light15=switch
Light16=moive
Light17=NVR
Light18=computer
Light19=player
Light20=button
Light21=power box
Light22=pump
Light23=router
Light24=scene
Light25=security
Light26=security
Light27=speaker
Light28=TV
Light29=watering
Light30=door
Light31=socket
Light32=humidifier
DI1=Contact S1
DI2=Contact S2
DI3=Motion-West
DI4=Motion-East
DI5=IR Beam-1
DI6=IR Beam-2
DI7=IR Beam-3
DI8=IR Beam-4
DI9=input9
DI10=input10
DI11=input11
DI12=input12
DI13=input13
DI14=input14
DI15=input15
DI16=input16
---nothing else.  Could this be the issue?
James
Yes, KBOX-pad application have fixed by "V" unit. because it display the voltage of the analog input port. what do you want to change?
