Full Version: ESP32 S3 set up issue
In a previous email I mentioned that I am using the SIM 7600 module with the ESP32 S3 WROOM 1U, however I can't use the serial monitor in order to receive information (I can't see data), I would like to know if you have any advice for the ESP32 S3 set up in Arduino firmware. See my below set up in tools menu:
[Image: 0?ui=2&ik=2d79881756&attid=0.1&permmsgid...j58g7e0&zw]
I followed you recommendation with ''USB CDC On Boot'' = ENABLE, and now I have below information in the Serial Monitor:
ELF file SHA256: 587cb4fa5
E (159) esp_core_dump_flash: Core dump flash config is corrupted! CRC=0x7bd5c66f instead of 0x0
E (167) esp_core_dump_elf: Elf write init failed!
E (172) esp_core_dump_common: Core dump write failed with error=-1
Rebooting...
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0xc (RTC_SW_CPU_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x40376f0d
SPIWP:0xee
modeBig GrinIO, clock div:1
load:0x3fce2810,len:0xfdc
load:0x403c8700,len:0x4
load:0x403c8704,len:0xabc
load:0x403cb700,len:0x2d40
entry 0x403c8890
E (113) quad_psram: PSRAM ID read error: 0x00ffffff, PSRAM chip not found or not supported, or wrong PSRAM line mode
E (116) spi_flash: Detected size(8192k) smaller than the size in the binary image header(16384k). Probe failed.
assert failed: __esp_system_init_fn_init_flash startup_funcs.c:95 (flash_ret == ESP_OK)
Backtrace: 0x4037654e:0x3fceb120 0x4037c65d:0x3fceb140 0x403830bd:0x3fceb160 0x4200a903:0x3fceb290 0x4200bd8b:0x3fceb2b0 0x4200bdc5:0x3fceb2d0 0x403768f5:0x3fceb300 0x403cc974:0x3fceb340 0x403ccd39:0x3fceb380 0x403c88fd:0x3fceb4b0 0x40045c01:0x3fceb570 0x40043ab6:0x3fceb6f0 0x40034c45:0x3fceb710
I think I need to change something else in the Tool config but I'm not sure.
Thanks.
we can't see your photo. please upload your arduino project setting photo. such as BORAD type.
Please let me know if now you can see the image
This image is before changes
your photo showed you have already downloaded firmware, what problem with you?
In a previous post I mentioned that I am using the SIM 7600 module with the ESP32 S3 WROOM 1U, however I can't use the serial monitor in order to receive information (I can't see data), I can upload the firmware to ESP32 but after upload the firmware I can't see a response in serial monitor, I only can see the failures that I sent in previos post after Enabled the "USB CDC On Boot''.
if you want monitor log data from USB-C port, you should enable "USB CDC On Boot''.
Yes, I did your recommendation I enabled "USB CDC On Boot'', and the error results in serial monitor are below (please see attached images for your reference):
ELF file SHA256: a6759c6aa
E (149) esp_core_dump_flash: Core dump flash config is corrupted! CRC=0x7bd5c66f instead of 0x0
E (157) esp_core_dump_elf: Elf write init failed!
E (162) esp_core_dump_common: Core dump write failed with error=-1
Rebooting...
Build:Mar 27 2021
Saved PC:0x40376eb1
SPIWP:0xee
entry 0x403c8890
E (113) spi_flash: Detected size(8192k) smaller than the size in the binary image header(16384k). Probe failed.
Backtrace: 0x403764f2:0x3fceb120 0x4037c1d1:0x3fceb140 0x40382c31:0x3fceb160 0x4200a803:0x3fceb290 0x4200bc8b:0x3fceb2b0 0x4200bcc5:0x3fceb2d0 0x40376899:0x3fceb300 0x403cc974:0x3fceb340 0x403ccd39:0x3fceb380 0x403c88fd:0x3fceb4b0 0x40045c01:0x3fceb570 0x40043ab6:0x3fceb6f0 0x40034c45:0x3fceb710
which kincony board you are using? take a photo.
I am not using Kincony board, I am just using the ESP32 S3 chip on a board
Do you have any other comments for my issue?
