Full Version: Kincony + Somfy LM100
Good day, I recently bought a kincony f16 for myself. I want to control underfloor heating and electric curtain rods.
Please tell me if you can make a current video where using the new kincony f16 or f24 controllers you can control electric curtain rods via rs485.
For example, how to connect a somfy A-OK LM100 curtain rod.
Thanks in advance.
if your "A-OK LM100 curtain rod" is RS485 device, it have own private protocol, KCS firmware will not support directly. if you use home assistant by ESPHome, you can try to config yaml for the curtain rod.
Tell me which plz curtain rod Kincony f16 works with without problems and are there any examples???
usually control one curtain motor by two relay, then set INTERLOCK for relay.
Do you have video examples or specific examples? I haven't seen any video tutorials on this topic on the channel. Although automation of curtain opening is in great demand, will you be able to make a detailed video on this topic?
