Full Version: Manual Control Switches Not working
Hello... I have a problem.
The manual control switches of my KCS_KC868_E16S are not working, they are not active.
my latest update is “KCS_KC868_E16S_V2.2.8.bin”
It was not working before the update.
I connect to the device via web. buttons work but manual switches are not active
[Image: image.png]
https://www.kincony.com/forum/showthread.php?tid=2241    ( #08-E16S-Ethernet_Web_server_code)
I installed the file on this page but it doesn't work, the ethernet lights don't come on. Only after installing the version update the ethernet lights come on and I can connect via web
if you want digital input toggle relay output, you need to set by IFTTT webpage.
here is KCS v2 online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
Hello. I am actively using homeassistant now, I can turn on and off digitally, but my manual switches are not active. my wall buttons do not work.
manual switches were working when I first bought it, after the software update they stopped working
I did the steps on the page you suggested and installed the “KCS_KC868_E16S_V2.2.8.bin” version using the flash download tools program.
in case there is a problem with the new version, I also installed the old version and tried it, the result is the same.
do you have config the IFTTT? it MUST config it.
