Full Version: Lora code
Is there LoRa code for me to peruse while I wait for my new board (KC 868-A6 I think)
Thanks!
https://www.kincony.com/forum/forumdisplay.php?fid=22
here are SX1278 LoRa module arduino demo code
Thanks. I have a LoRaWAN gateway running Chirpstack V4 locally.
I think I need more than just the LoRa library. Is it possible to install this library?
https://github.com/mcci-catena/arduino-lmic
From memory in Chirpstack the device needs a unique identification number and an activation code.
i am not sure, you can test it. there are many LoRaWAN arduino library on the internet.
Just received the item. The LoRA antenna just gets soldered onto the pin at the extreme inside away from the relays like in the photo I found?
take a photo
Does that make sense? I was going to solder the antenna to the top left pin on the LoRa PCB.
[Image: attachment.php?aid=2332]
Thanks. That is the pin I was going to solder it to but it’s good to have confirmation. If I solder it upright like that will it fit in the box? I was going to solder it in an angle but that looks nicer.
If I solder it upright like that will it fit in the box? sure, no problem, the plastic shell space is enough.
